Question about Starbucks Coffee Makers & Espresso Machines
How to locate and replace thermal fuse on a Starbucks Barista el60 burr grinder
  • 1089 Answers
SOURCE: Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Posted on Jun 27, 2009
  • 4088 Answers
SOURCE: starbucks barista burr grinder: the motor runs but
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Posted on Apr 06, 2010
  • 1340 Answers
SOURCE: Our Starbucks Barista burr grinder
Here is a link about a person who had a similar issue.It doesn't answer your question yet but I am searching.When we were looking for a coffee maker last year,I think at BB&B they said that DeLonghi makes all Starbuck's coffee machines.We were disappointed with the DeLonghi.I am checking around to see who makes it though,and possibly an image so I can see better what you mentioned.Greg Will reply again when I find something more.
http://coffeegeek.com/reviews/grinders/starbucks_barista_grinder/Cafetiere
Posted on Dec 02, 2010
SOURCE: Starbucks EL60 coffee grinder: where
Did you find one? I need one also.
Posted on Aug 16, 2011
I have Barista grinder. I've had grinder for about 3-4 years and it stop moving. I unplugged cord, tried to turn the feeder and plugged in still not moving except timer is clicking. I wonder why it...
Hi It could be the timer switch but if you hear the timer move(whirring) it is probably OK. There is a thermal fuse on the motor that will go out and you just have to replace the thermal fuse. Its under the wrap on the side of the motor. Which grinder do you have?
Jul 07, 2011 | Starbucks Barista Burr Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
Electrical cable burn and grinder stopped working Should I replace thermal fuse.
If the wireing burned, you should replace it as well as the diode.
Feb 15, 2011 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
Apr 06, 2010 | Starbucks Barista Burr Grinder
Motor stopped working
Hi
There is a thermal fuse on the side of the motor to prevent the motor from burning up. You can replace the fuse (it is a 103c thermal fuse, crimp it on ) and you should be in for more grinding.
It could also be you timer switch, or bean hopper switch, or a broken tab on your adjustment collar.
Jul 25, 2009 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Non-working Starbuck's Barista burr grinder.
Hi
Remove bean hopper
The thermal fuse is to protect the motor its a 104C
May 12, 2009 | Starbucks Barista Burr Grinder
Hi
Remove bean hopper
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
