Question about Irons
This country is known for its rich mineral deposits.
Can spring water be used instead of distilled?
The reason that distilled water is suggested it is the mineral deposits that are in the water.
Any other kind of water than distilled has more, and possibly a lot more minerals than distilled.
That means, it might depend on how soon you can no longer use your iron, as it is clogged with mineral deposits.
How much minerals are in the spring water is anybody's guess, some more, some less.
God bless your efforts.
Apr 07, 2016 | Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Apr 09, 2010 | Rival IR620 Iron
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
Ther is white build up in it. i used the self
The white build up is probably mineral deposits from the water used in the iron. Try using a solution of white vinegar and water, about 50% each, and let the solution heat and steam through the iron. You may need to do this a few times. If this does not work, try using a product such as Lime Away or CLR to remove the deposits. After treatment, clean the bottom of the iron after it cools. It's a good idea to use distilled water in the iron to avoid all those mineral deposits.
Hope this helps!
Aug 12, 2009 | Euro-Pro Shark GI490 Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
