Question about Dishwashers
Glasses do not come clean in the upper rack but do in the lower. Is there someplace that should be cleaned out to make the upper rack work again
  • 55 Answers
Not knowing what dish washer you have I would check on the sprayer make sure it turns or is not blocked in any way. If the water can't spray up you will not get clean dishes.
Posted on Apr 28, 2017
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwaser not rinsing properly
I had this problem twice with my Bosch and both times required different fixes but they both worked. 1. I got this one out of the manual. Make SURE that you push the upper rack totally back. There is a connection back there that fits into a fitting on the back of the rack and pushes the water through the upper arm. 2. I had taken off the extra rack that attaches to the back of the lower rack. Then I put it back on wrong. It should not have the prongs appearing behind the rack. Both of these situations caused cloudy/dirty dishes. Also, because of the lack of water, it clogged up the filters. Remove the filters and clean them well. Then make sure you have neither of these issues going on. My dishwasher returned to great washing.
May 01, 2008 | Dishwashers
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
