Question about GE Washing Machines
My Ge profile washer model ptwn8050m0ww will not drain but pump is operational.
I tested the pump with secondary power. There are no kinks or clogs in drain hose. Is it the control board or pressure switch that needs to be replaced?
    Master:
  • 487 Answers
Probably the solenoid that opens the drain
Posted on Apr 28, 2017
GE Profile model WPRE6100 only spins slow....
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 02, 2010 | GE Profile WPRE6100G Top Load Washer
    GE top load washer will not advance to drain and spin
    Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
    The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
    Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
    Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
    Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
    clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
    Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
    Washer will not drain
    I think you may be right about the pump is working to hard. May need to replace it.
    Nov 10, 2009 | GE Profile Performance WPSF4170WAA
    Water leaking from bottom, lots of suds.
    Hi
    Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
    Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
    Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
    Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
    This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
    Please rate the solution if you find it useful and helpful.
    Thanks
    Rylee
    Sep 22, 2009 | GE Washing Machines
    Washer will not drain says check for kinks in hose
    Check the following to address this issue.
    1. Clogged drain line or water pump
    Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
    2. Water Pump
    If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
    Jun 04, 2009 | GE Profile WPRE6100G Top Load Washer
    Our GE Profile Deluxe washer is not draining
    Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
    Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
    Jan 06, 2008 | Washing Machines
    Washing Machines Logo
    128 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
