Question about Polaroid Televison & Video
I have a Polaroid Q25 and 1. When I open it if get a message across the screen Card Locked how do I fix it? 2. When I open it makes a buzzing noise
  • 9098 Answers
SOURCE: Microwave won't work
F6 usually means a fault in the controller or keypad. You could try to unplug it for several minutes, then plug it back in. If it still fails, maybe you or a friend can disconnect the power cord, unplug the keypad strip internally, then plug the power cord back in and try it with the keypad still disconnected. If it does not fail again, you have a wet or shorted keypad and can dry it or order one. If it does fail again, the control board is bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: Sorry I didn't get to answer this before the bogus answer was posted. I've been tied up and away from the PC.
Posted on Apr 10, 2007
  • 750 Answers
SOURCE: my whirlpool aide by side fridge icemaker is making buzzing or humming noise
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
SOURCE: my xbox freezes up, lines go across the screen, and makes a weird noise. how can i fix it???
How can we fix this? or where can we take it to be fixed?
Posted on Apr 29, 2009
  • 321 Answers
SOURCE: File error and Card error Message on Polaroid i531
download card error programme
Posted on Jun 18, 2009
  • 335 Answers
SOURCE: no picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Posted on Nov 08, 2009
I have a locked disc message across my view screen. Camera will not work. carol
If that camera uses an SD card, there is a little switch tab on it, this prevents data from being written to the card, check the card switch.
Nov 03, 2016 | Cameras
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Apr 25, 2015 | Polaroid FLM-3734B 37 in. LCD HDTV
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
How do you get rid of card locked message on Polaroid i832 when there isnt even a card in it , just internal memory
It's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
Jun 01, 2009 | Polaroid i832 Digital Camera
Says card cover open when turning on.makes a buzzing noise then shuts back off
you should have either dropped it down the floor or it should have been affected with water or solvents. the only way is you have to take it to the service centre to change the lens array.
May 27, 2009 | Olympus FE-20 Digital Camera
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Buzzing until warmed up
This is caused by a defective capacitor in the power supply board. A very detailed answer is given by stiv0. His solution is for a "no power" or "black screen" condition, but this also fixed my noise on power up. I had noise that went away, but eventually it stayed on all the time. His explanation is correct except in describing how to get the back cover off. He says to take the 3 screws off the back of the black plastic cover on the back and then "pry" up the plastic. Actually if you slide the plastic down about 3/8 inch the cover will lift out easily. I fixed mine today in about an hour.
Hope this helps.
Sep 10, 2008 | Polaroid FLM-3732 Television
Televison & Video Logo
23 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
