Question about Homelite Garden
Homelite ut33600a will start but will not stay running
    New Friend:
  • 3 Answers
That could be 1 of several things (carburetor, air leak, a pinhole in the gas hose, to name a few). You may as well just rebuild the carburetor and replace the hoses and that should take care of it if it is done right.
Posted on Apr 28, 2017
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
Jul 15, 2017 | Homelite Garden
2 cycle 30 cc homelite will start but not stay running
I had one of these a few years ago which started doing the same thing. I get fed up with it, and was going to throw it away. I gave it to a friend who found the fuel system was partially blocked. After running some carby cleaner through it, it worked fine. Its still going now...
Aug 18, 2014 | Homelite Consumer Products Tiller...
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
My homelite yard broom is hard to start and stay running
check the scrren inside the carb to see if it is ditry or needs replacing.
Jul 16, 2012 | Homelite 'Yard Broom' Leaf Blower
Homelite chainsaw won't stay running
Make sure you are using fresh fuel mix (50:1 ratio). Don't use boat motor oil in a saw--only modern synthetics made for saws. Always premix the oil and fuel thoroughly before adding to the saw. Check the fuel filter for plugging and the condition of all fuel lines, plus the primer bulb condition. Check all carburetor fasteners for tightness. Make sure the air filter and muffler are not plugged. If still no help, you may need to service the carburetor. For an excellent article on Walbro carburetors, go to: http://www.drystacked.com Pay particular attention to the placement of the lower diaphragm and the cover gasket--interchanging positions of them cause many headaches. Adjustment of the two jet screws require a special 'D' screwdriver which may necessitate a trip to a servicing dealer for adjustment. Hope this helps!
May 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Home lite 20002a won't stay running
when you use the primer bulb does it pull fuel out of the tank and fill the carb and any extra returns to the tank ? I am sure this is the case since you can get it to start and then it runs out of fuel. It sounds like you may have a dirty filter in the tank or the diaphrams in the carb are stretched from age or dried out from sitting either way the first thing I would check / replace is the fuel filter and if this doesnot correct the problem i would then rebuild the carb. Good Luck i hope this helps you out
Sep 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Leaf Blower won't stay running
Hey .. Did you replace the inlet screen in the carb ?
or
Either the carburetor, block behind it, or the cylinder are loose. Common Homelite problem.
Let me know ....
Mar 27, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
55 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
