Question about Sony Televison & Video
I have sony kdl55hx750 blinks 3 times volt going from hight to down
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: NO HIGHT VOLTAGE
sounds like the LSB is defective as that controls all the high voltage and deflection circuits. If you go to the following link and leave them a email with your model number they should have a LSB board for your model.
http://servicemanuals.vstore.ca/
Posted on Nov 23, 2008
  • 87 Answers
SOURCE: sony wega 42e2000 red light blinkes 3 times
YOUR LAMP DOOR OR COVER IS OPEN OR WARPED
Posted on Apr 15, 2009
3 time blink sony - Sony 40 KDL40EX520 LCD TV what is the problem
try a power reset first. 3 flashing light is bad main logic or power board ,check for standby volts if ok replace main logic board
May 14, 2017 | Sony Televison & Video
How do I fix my KDL55HX750? It will not turn on. No sound or picture. Just 3 blinking red lights. What should I do next?!?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 26, 2016 | Televison & Video
How do i fix/repair 6 blinks sony bravia LCD KLV-46Z450A & shutting down problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 20, 2015 | Sony Televison & Video
Tv plays about 2 minutes and picture and sound goes off, comes back on.Does this 3 times then tv shuts.turn tv back on and repeats sequence.
there is main board defective please replace the main board 3 time blink is dc alert which is happened in side the system ic & we cant replace the system ic so we replace complete main board
Apr 20, 2015 | Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p...
My Sony TV that is only 9 months old will not turn on the Red LED is blinking 8 times and there is a pause and it blinks 8 more times. Thanks
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
If you're sound in electronic, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
It sounds that the TV is mew one, and come under warranty period. If so, it will be best to get it repaired by the authorized service center for Sony.
Oct 29, 2013 | Sony KDL55HX750 55 BRAVIA LED Internet TV
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
NO HIGHT VOLTAGE
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Nov 15, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
