Question about Kodak EasyShare C643 Digital Camera
I keep getting the red hand never the green hand
I keep getting the red hand and never the green hand but the picture looks good on screen
    Problem Solver:
  • 19 Answers
Hi mariah, all the red hand means is that the camera was moved slightly when the picture was taken. If the picture looks fine I wouldn't work about it, or you could do like I did: I went to walmart and found a $25 tripod that works really well.
hope this helps!
Posted on Dec 23, 2007
I have the same problem(redish screen with no green at all)
Does Tube Light up? with TV on Look down into Tubes and see if picture is clear or you can bearly see picture or not at all Your Projection fliuld may need changing Ive seen where tubes are still lighting but No picture showing inside tube---- Bad Coolant Fuild Call Mats for fuild and for Tube if thats what it is Call Encompass 1-800-638-3328
Oct 05, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
What to do when you only have Green on a CRT Projection TV.
If you have a picture, but only in green on a 3 crt projection TV, I would try turning up the drive for the red and blue guns. They have probably changed over time and red and blue have lost drive and need a boost. Green makes up 70 percent of the picture compared to red and blue so the drive would not have to drop much to lose red and green but still have green. Keep in mind that this does mean that the CRTs are dying and may not have too much time left.
To turn up the drives first remove the back cover on the bottom half of the machine. Be very careful as you will have to work on this unit live. Do not touch anything other than what I tell you and keep one hand in your pocket whenever possible.
First look at the space above the main circuit board. Somewhere across the beam supporting the CRTs you will see a square box with 6 controls (shafts). You can locate the box if you follow the wires from the flyback to the box. The flyback is located on the power board and produces the high voltage. It will have 4 large red rubber wires coming out of it. Three go to the focus divider block (the box in question) then they go on to the crts (red, green, blue).
Once you locate the focus divider look at it closely. The focus controls are on top and the drives are on the bottom. They should be marked red, green and blue. You want to turn up the red and blue. Tune a picture with as much black as possible. While watching it turn up the red until you see a red tint or streak then turn down until it just disappears. Do the same with the blue. You may want to touch up the green also for good color balance.
If the set is working OK and the CRTs have enough drive left, your picture should look normal.
Thanks for using FixYa.
on Sep 22, 2010 | Toshiba 50H81 50" Rear Projection...
Having picture problems 61 in phillips hdtv
Replace the STKs IC on the convergence PCB.
May 18, 2009 | Televison & Video
Colours red and green are out of sync
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Apr 18, 2009 | Philips 55PP9363 55" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Red and green curved lines when the screen is dark
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Feb 09, 2009 | Sony KP-57HW40 57" Rear Projection...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Red and Green
A screen drive issue is at hand and will require the help of a shop to get it back up to snuff....accordianman
Sep 11, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Mitsubishi vs-60803
greetings from belize take your set to a tech and have him look at it.good luck.
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Kodak EasyShare C643 Digital Camera Logo
161 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
