Question about Cell Phones
Rolling office case
The battery is showing fully charged but it doesn't charge when I plug in my phone
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
SOURCE: nokia 6500 classic charging problems
I have had exactly the same problem, and have replaced both the charger and the battery.
I think the problem lies in the contacts between the charger and the bayonet and the battery..
Soooo
I put a couple of peices of folded paper behind the battery, making a very very snug fit.
then, (this is a bit fiddly)
i carefully folded a slim peice of paper to wedge behind the charger pin and the back of the bayonet, so the pin is pushing against the front of the bayonet.
( to do this, position the paper over the pin and push into the socket at the same time.)
works like a treat :)
if you had exactly the same problem, it will be due to the charger wobbling around about the socket.
this ensures a tight fit and means it maintains contact all the time.
good luck, and i hope you haven't started to tear your hair out quite yet.
Posted on Mar 23, 2009
  • 6 Answers
SOURCE: Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Posted on Jun 01, 2009
SOURCE: phone won't turn on at all battery was fully charged when it died
just had the same problem! hold the top sleep button and the middle button for at least 10 seconds until the apple logo comes up then try start it
Posted on Sep 24, 2009
Testimonial: "I had tried that but I guess not long enogh so thanks for the info. Very Happy to get all my info back!"
SOURCE: Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Posted on May 15, 2012
Why won't it turn on?
plug it in to the charger againm, it may show as charging and come on. If it does your battery needs to be replaced. A battery can show fully charged on charger nut not hold the charge when removed
Aug 09, 2015 | Cell Phones
Iphone wont charge
The battery might be damaged, but in most cases you can just let it be plugged in like you normally do. It doesn't show "recharging" because it has been too drained.
Turn on your phone after 15 min. in the charger.
If it still doesn't work, then you have to ask a store that supports Iphones.
Aug 06, 2014 | Apple iPhone 4S
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
Nokia x3 battery not fully charge solution
Try taking the battery out for 2 minutes or so... Place back in the phone and charge while the phone is off.. Give about an hour! If you still doesn't charge you might want to see if the charger has a short or if you need to replace the battery.. Hope this helps!:)
Jul 23, 2012 | Cell Phones
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Concerned.
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
My phone is 3 yrs old. Lately the battery will not keep a charge. I charge it until it is fully charged, however if I talk for more than 5 minutes the phone logs off and dies. I turn it back on and the...
It sounds like your battery is faulty. 3 years of use is enough to wear a battery out. Try replacing the battery and see if the problem clears up. If it doesn't your phone may have an internal faulty, but I am going with the battery.
Apr 15, 2011 | LG enV VX9900 Cellular Phone
How I know my lg lsp 350t has full charged
When your lg lsp 350t is fully charged, it stops reading like it is charging. You can also turn off the phone and plug in the charger, once it is full, the battery meter will turn blue or show battery full. \but when the phone is on, the way you will know that it is fully charged is that the battery shows a full bar and does not charge anymore.
Hope this information helped.
Jan 14, 2011 | Cell Phones
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
