Question about Brother Sewing Machines
I have a brother CS-8072 sewing machine and need help winding bobbin. I followed the instructions in the manual but it didn't work.
  • Brother Master
  • 10,712 Answers
What were the results of your bobbin-winding attempt?
Make sure the thread path is correct for bobbin winding and that the thread is seated in the tensioner. Most machines, it is better to NOT wind fast--although your machine says the opposite (???).
It looks like your thread comes off the spool goes to the left, through a guide, down to the front of the tensioner and the doubles back to go behind the tensioner before going to the bobbin. (Looks the thread goes counter-clockwise in front of the tensioner, then doubles back and goes clockwise around the back of the tensioner.)
Also, the problem may have to do with the spool type you are using. Try a different thread and spool--AVOID old or bargain bin threads.
If you still have problems, there is a stand-alone bobbin winder (called Sidewinder) for about $30 that is helpful to have. (Verify it will work with your machine's bobbins!) It is great because you can wind bobbins without unthreading your machine and it saves wear and tear on your machine.
http://support.brother.com/g/b/manuallist.aspx?c=us&lang=en&prod=hf_cs8072eus&flang=English&type3=348&type2=69
Posted on Apr 28, 2017
My brother cs 8072 stitch length not working.
Are the feed dogs fully up and clean?
With the unthreaded machine transport a piece of paper with the feed dogs?
Is there a presser foot pressure adjustment? -- if so, it may need tweaking.
Do you have a tangle of thread under the needle plate (= throat plate) or hook and bobbin case area?
Do you have the stitch length set to greater than 0?
Jun 26, 2014 | Brother CS-8072 Computerized Sewing...
Cs-8072 Red light
It's just a thought, but the red light will or should come on as soon as you push the bobbin winder in position to wind a bobbin. The red light should turn off when you push the bobbin winder back to the original position. I can't tell you how many times I have been dumbfounded after having done this. I hope this helps.
P ;)
Jun 03, 2014 | Brother CS-8072 Computerized Sewing...
Exterior Bobbin winder does not turn or wind a bobin? Model CS-8072
you will need to turn the speed to maxium then press the start button. I attached a site that has your manual and shows great pictures of how to wind a bobbin.
brother model CS-8072
Mar 15, 2011 | Brother Sewing Machines
How do I wind the bobbin on a Brother sewing machine Model CS-8072?
Go to brother.com and get a manual download for free, make a copy and you will learn all about your machine
Jul 20, 2010 | Brother CS-8072 Computerized Sewing...
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
Bobbin won't wind the thread
open the machine there is a wrong black rubber that need to be replaced
Aug 02, 2009 | Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
