Question about Fisher and Paykel Dishwashers
How much it cost for fisher and paykel dishwashers technician cost
    Master:
  • 487 Answers
Not cheap
Posted on Apr 28, 2017
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel top dishwasher is showing F3 damage after a short circuit we had. How do I fix?
This is serious. The thermostat is not working thereby causing the heater to overheat and the protection circuit cuts in. The only way to replace thermostat is to replace the whole heater element as the unit is fully integrated. Will need technician to replace the heater element unit as it is very complex assembly.
Feb 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Jan 03, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Fisher & Paykel DishwasherDW60CCX1 - bought new 22.5.12. Error code E9. How to fix this please, as not in the instructions book!!
The code like E9 or F9 in F&P dishwasher usually implies controller fault. No solution but to call authorised technician unless you know how to replace the controller. Need to have a diagnostic tool to check what is happening. You should still be under factory warranty.
Dec 22, 2012 | Fisher and Paykel Dishwashers
Hi ya. we have a fisher and paykel nautilus dishwasher. and it has a fault. f4 is on the panel. and its not draining water. help please
This means something wrong with the water heater.
Most likely you will need to replace it. It will look something list this.
Will need a technician to fix it if you are not very comfortable to handle such equipment.
Please rate this solution.
Aug 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top seal is chewed on the top drawer of our Fisher Paykel dishwasher. How do I fix this?
You will have to get the drawer out from the housing.
This will help you find the extent of the damage. You will then have to order a new seal which is quite a complex part to replace as it is driven by two actuator motors one on each side.
Post a comment if you want to do it yourself otherwise call a fisher and paykel technician.
Jul 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I get an f-1 on my fisher paykel dishwasher
On this unit andyou might have to call a technician as the control is bad and has to be replaced and on this unit it can use one of several and just picking one could cost more than needed ,, these boards has numbers and codes or in this case i say call a tech but at lease you now know the problem / thanks
Jan 07, 2010 | Dishwashers
Our Fisher Paykel dishwashers are 6 years old. The top drawer is shooting water from top left corner when door is closed and leaking water everywhere.
Unfortunately these models do not last this long and you're lucky that it has. This means the rubber casing needs to be replaced and it may be more cost effective to buy a new dishwasher for the cost of the part and labor.
Nov 21, 2009 | Fisher and Paykel Dishwashers
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
27 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
