Question about Fisher and Paykel Washing Machines
Dw60chw1 fisher and paykel lights on the control panel except for timer display and if press any button it won't work
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
  • 126 Answers
SOURCE: control panel not working after "function lock" buttons pressed
MD,
Hit the up and down again and do away with the Function Lock.
Tom
Posted on Apr 24, 2009
  • 155 Answers
SOURCE: Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Posted on Feb 06, 2010
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
  • 88 Answers
SOURCE: Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Posted on Jul 27, 2011
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher and paykel start button does not actuate. The panel works, but just won't start the cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Feb 01, 2013 | Fisher and Paykel (IWL12)
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
My Fisher Paykel dw60cdw2 dishwasher stopped working mid cycle and I cant get it started again even aftre switching power off and pressing reset.. All lights on the console are working except the number...
had the same problem and it was the microswitch that is behind the door skin which is associated with the lock mechanism. got a new one and away she went
Aug 04, 2010 | Fisher and Paykel Dishwashers
Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Feb 09, 2008 | Dishwashers
Washing Machines Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
