Question about Fisher and Paykel Dishwashers
Dw60ch1 have lights on except for display time but won't work
Fisher and paykel dishwasher model no de 60chw1 freestanding dishwasher have lights on except for display timer and it won't respond to any button
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
  • 251 Answers
SOURCE: How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Posted on Jul 17, 2011
Fisher and paykel dishwasher pump constantly runs
Please clarify model of dishwasher. It is likely the motor compartment has flooded and it is shorting the power system. Turn off mains power to dishwasher to avoid damage to dishwasher. The source of flooding has to be found.
Jan 16, 2013 | Fisher and Paykel Dishwashers
How do I uninstall double dish drawers. I can take the drawers out but internal frame seems fixed
It depends on which model you have. The integrated model would most likely have the frame lodged inside the kitchen panels. The freestanding model should simply pull out after removing inlet and drain hose and power connection.
Jan 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
E4 error fisher and paykel dishwasher
There is a Y shape pipe under the sink's piping & it was blocked so I drilled & open a hole then the machine could has drained & worked.
Nov 08, 2012 | Fisher and Paykel Dishwashers
I have a Fisher and Paykel DW60CDX1 dishwasher, the display originally came up eith an error code for the door, which seemed to be the problem as it restarted with some pressure on the door, then it...
Old question, but for anyone else, hears the answer - http://www.recalls.gov.au/content/index.phtml/itemId/1015047
This model has a product recall, minehas done the same as described above, recall issued Aug 2012.
Mar 06, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
My Fisher Paykel dw60cdw2 dishwasher stopped working mid cycle and I cant get it started again even aftre switching power off and pressing reset.. All lights on the console are working except the number...
had the same problem and it was the microswitch that is behind the door skin which is associated with the lock mechanism. got a new one and away she went
Aug 04, 2010 | Fisher and Paykel Dishwashers
Please tell me where to find float swich in fisher and paykel dishwasher
is this dishwasher a dishdrawer unit or is it a freestanding unit. if it is a freestanding unit it has a pressure switch. if it is a dishdrawer it relies on how many amps it takes to turn pump. hope this helps. what is the problem with your unit? please reply 4 more help.
May 03, 2010 | Fisher and Paykel DS602 Dishwasher
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
