Question about Whirlpool Washing Machines
Clothes tangles around agitator and then water comes out of bottom. Whirlpool ModelWTW4800XQ1 Happens all the time now
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
  • 100 Answers
SOURCE: agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Posted on Oct 30, 2007
  • 27 Answers
SOURCE: Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Posted on Nov 02, 2007
  • 135 Answers
SOURCE: upper portion of Whirlpool agitator not turning
Here's a diagram showing the agitator to help you replace it. You can see the other parts here.
Posted on Jan 07, 2008
shaggyrat
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
What will cause this washer to tare up cloths
If you are getting ripped or torn clothes then most likely they are getting bunched up underneath the center piece that turns. These usually go back and forth and not all the way around in order to keep from bunching and tangling. It may be getting caught up on a lose bolt or something inside and under the center piece. If you can't figure it out just get a new one and part that one out or sell it at a garage sale. The electrical board and dials alone are worth a hundred bucks to the right buyer.
Mar 23, 2015 | Whirlpool WTW6400SW Cabrio Washer
Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Dec 09, 2014 | Washing Machines
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
Clothes get tangle around agitator
unplug the power. open the top of the washer to expose the tub. Hold on to the top layer of clothing and rotate the tub by hand in the direction that untangles the clothes.
Nov 02, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
Clothes get caught under the agitator and tangled around the agitator and have to unravel the clothes from the agitator
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Aug 16, 2010 | Whirlpool LSQ8543J
Lint from washing machine
Fill the tub to the bottom of the agitator with hot water and add 1/2 to 1 gal of white vinager and let it sit for a few hours. Spin out the water and run thru a light load without clothes. When you are running a load lift the lid and observe the clothes movement, The items should be circulating from top to bottom. If they are just wiggling around it is overloaded and the clothes do not have room to move. This wears on the fabric creating lint. The agitator is for the water not the clothes contrary to popular belief. The clothes are actually washed with the water movement not beaten by the agitator.
Eric
Jul 02, 2009 | Washing Machines
Agitator Dogs tangle clothes
No - The clothes will not agitate properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Washing Machines Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
