Question about Bernina Sewing Machines
Bernina 350 buttonhole - when I hit the reverse button, the machine just keeps stitching backwards. It doesn't stop to do the tck and then go forward again.
  • Bernina Master
  • 12,241 Answers
Here's a video:
It looks like the Reverse button just needs to be "tapped." On my machine, if I hold the Reverse button too long, it turns into a continuous reverse until I deactivate it.
Bernina 350 16 Buttonholes
If it still won't make buttonholes, you should take it for service. On machines that have the "eye" on the presser foot, the machine needs to be calibrated to use the buttonhole presser foot. Be sure to take the presser foot when having the machine serviced.
Posted on Apr 28, 2017
Bernina 830: When making a buttonhole... the zigzag #1 stitch on left side looks nice... then the #2 bottom bar tack looks good...
Please tell us which Bernina 830 you have--old mechanical Record or new computerized?
Here's a recommendation from a Bernina owner (Ellen Rosenthal on Yahoo Group "BonosBerninas":
I agree about the buttonholer. The reverse stitching never looks as good as the left or forward side. I “hack” this by pivoting my fabric and only
going forward-avoiding the reverse stitch. Also helps to do the whole process twice and to use some tear away or wash away interfacing.
There is another Yahoo group called "BerninaThirtySomethings" that is a great resource.
Jan 25, 2018 | Bernina Sewing Machines
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Sep 19, 2014 | Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
Bernina 240, won't complete the buttonhole
Double check the instructions and if there is still an issue, call the Bernina dealer and tell them what is wrong.
Ask if someone will be available to look at the machine when you come in .... you need one-on-one assistance.
Mar 07, 2010 | Bernina Sewing Machines
Buttonholing - Bernina 950 (semi-industrial)
This sewing machine looks exactly like the Berninas that I own, although my are not industrial. You just use the dial to make each side of the buttonhole, only having to set the stitch length to super small. The way you make buttonholes is this:
Think of the buttonhole as a square-ish capital O, with the center of the bottom of the O as the point where the button shank will lie when buttoned. Place the marked buttonhole area under the buttonhole foot, with this bottom point directly under the foot, squarely in the center of the 'hole'.
-Turn the dial to 1 and the long left edge will sew in zig zag stitches; stop the machine at the top of the O.
-Then turn the dial to 2 and the top edge of the O will sew; stop the machine after half a dozen stitches.
-Turn the dial to 3 and the right edge will sew; stop the machine at the bottom of the O.
-Turn the dial to 4 and the bottom edge of the O will sew; stop the machine after half a doze stitches.
-Turn the dial to 5 and run half a dozen stitches; this is a line of straight stitches that will 'tie off' the buttonhole.
Try this with a plain piece of fabric. Just put the fabric under the foot and dial away. You'll see how the stitches stitch.
I'll send a copy of instructions from my manual to you if you want. Email me at: pink8006@yahoo.com.
Sep 05, 2008 | Bernina 2500DCET
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Automatic buttonholer won't work
Your buttonhole foot needs to be recalibrated to your machine by a technician. Takes about 5 minutes or so.
Apr 01, 2008 | Bernina Virtuosa 160
Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Feb 28, 2008 | Bernina Activa 130
Sewing Machines Logo
55 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
