We have a aircomand heron 3 air conditioner in our caravan, model 476000, but the vent selection wheel doesn't budge, any answers?
SOURCE: air conditioner blower motor resister on dodge grand caravan
I have a 2002 Grand Caravan and it is located behind the glovebox. It may be in the same place.
Posted on Aug 06, 2008
in my 2004 grand caravan it's behind the glove box and left of the blower motor. disconnect the wires first then remove the 2 screws to pull out the resistor unit. First make sure you have removed the negative of your batterie. I had the same pm that prevented the blower motor to operate in any speed. I hope this will help
Posted on Dec 25, 2008
  • 65 Answers
SOURCE: air conditioner vents only work on the floor vents.
being that it a dodge product they probably have used a vacuum based motor to switch where the air comes from. If this is the case then you must have leak somewhere. These are not easy to find they can take a lot of time or be quick it depends on the leak. to clarify does the heat or vent come out the top? is it supposed to?
Posted on Jun 22, 2009
r_mcalhoun
  • 166 Answers
SOURCE: Dodge Caravan 1998 air conditioner
there a restor on the front frame rail on the drivers side that gos bad it behind the bumper
Posted on Jul 17, 2009
SOURCE: my vent only blows hot air. The air conditioner
check cabin air filters located in the rear of the glovebox there is a cover then a small door to access them
Posted on Sep 04, 2009
How do you separate the blower motor housing from the fresh air vent?
Dodge Caravan Blower Installation
ZooSplash ...look for that on YouTube and it will help explain above answer in video form
Apr 10, 2015 | 2002 Dodge Grand Caravan
Why does water shoot out of my window ac. it shoots our of the vents that blow the cool air?
1) Your AC has a VERY powerful blower. 2) The intake air filter is probably really clean (if not recently washed). 3) It is extremely humid... The water is likely condensation on the evaporator (totally normal), but because the air is flowing so well and fast, it doesn't have enough time to drip down.
Jul 20, 2011 | Gibson Thru-Wall/Window Air Conditioner
Is the gas stove Dovre model DV450, by heatilator, serial # GA384694 a B -Vent or Direct Vent?
Janny, generally with Heatilator gas fireplaces, the letters in the Model Numbers indicate whether it's a Direct Vent or a B-Vent. In your case, it's a Direct Vent. Had it been a B-Vent the Model Number would be BV450.
Hope this answered your question. Please be knid enough to rate my reply to you. Thanks.
Mar 24, 2011 | Heating & Cooling
Hi i have a Coleman 8000 series aircon in 2007 model Jayco Caravan we have just been away for 4 days and it was leaking water through the vents onto the floor what causes this does anay one know as it...
Please check drain tray is not blocked.And also check Evaporator coil for dust blocking. Clean drain tray,coil and air filter. Check fan motor speed. If less speed, replace capacitor.Thanks.
Feb 21, 2011 | Coleman Mach 15 Air Conditioner
Not sure if i need to vent my amana air conditioner model apn12hj when i want to use it in heat mode
Sorry to read about your problem, I hope this helps you out.
No need to vent, as this is a electric unit, no gas
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Amana Portable Air Conditioner
Heat & air in our 06 Dodge Caravan won't blow out at the floor
unfortunatly yes the vent arm must be brokin and probaly is the cable going to it most of them u can access that by taking the cover where vent turn is located and just have a boo and see if its off or not
Dec 08, 2009 | 2006 Dodge Caravan
Jul 13, 2009 | 1998 Dodge Caravan
Air conditioner staying on...
Many cars use air conditioning as part of the defrost function. Cold air will clear windshield faster than hot air.
Aug 01, 2008 | 2001 Honda Civic
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
