Amp powers up but just hums
With out a guitar plugged into it it just hums i chkd the power going to speeker wires and its 40 vdc the leds light up finn turning up or down the vol still no change plug a guitar no change plucking strings no sound just huming the amp is a bassman 60 by fender it belongs to a buddy of mine i pulled the pcb and found that where the 2 big caps are there are 2 750 0hm 2watt resistors under them the board is kinda burnd looking but the reverse side shows no broken joints or traces i chked the resistors and they read arround 750 - 753 ohms caps may be bad but im thinking more along the lines of the two diodes could have something to do with it but im not sure
  • Herbert Sparks
    Herbert Sparks Aug 04, 2009
    i chkd the 2 power trannys in this amp and they chkd out ok even though they chked ok i put 2 more in anyway and still the humming when power is applied to the amp with all pots set to 0 and no guitar hooked up ....any more ideas?
    oh btw the transistors are 2sd1046 i used a digital multimeter set to diode chk and ran the test i tested in circuit and after i removed them
  • 4,234 Answers
The output transistors are probably shorted. There should not be any DC voltage going to the speakers. DO NOT run it this way for long or you will damage the voice coils of the speakers. This unit needs service. Expect a parts cost in the $25-$40 range.
Dan
Posted on Jul 25, 2009
Testimonial: "that was the problem its fixed and works great thank you and sorry for the late responce but with work and my electronics hobby no time for anything"
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 20, 2017 | LG Televison & Video
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
Well i used to have this really bad guitar that has this grounding problem (humming all the time unless u lower the tone or touch the strings or any metal object on it) well i always blamed the guitar for...
This would only mean two things:
1. you have a bad capacitor in the circuit or the grounding on the circuit is broken and not filtering the obvious line noise from the circuit.
2. You have what is called, dirty power. That is when you have some kind of electrical device plugged that generates line noise which can be even a florescent light as they generate line noise.
Please take the following steps to narrow down the issue.
Take your setup and plug it in some where you know others can setup their rigs and it is using clean power. If, the humming goes away then it is dirty power where you originally setup.
If, it is still humming then you will need to take your equipment to a qualified marshall dealer have them look at it.
Jul 13, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
My Marshall Haze 40 Amp started making a very loud humming noise after a couple hours of playing.I let it cool down,and turned it back on and the noise came back after a few minutes
may be one of the electrolytic capacitors in the power supply has become leaky...this is a common problem among amplifiers...so you let it cool down..then after a period of time the capacitor heats up and then causes the hum...the power supply caps filter out the 60 hertz ac line noise...which is probably the frequency of the sound it is making...this is a good indication of these caps going bad....another thing you can check is to see if the amp is properly grounded(eg: the ground pin on the plug is present) and that you dont have an open cord or input
Jul 10, 2011 | Marshall Amplification Marshall Haze 40...
I have an american delux telecaster with noisless pickups and it started to produce and annoying buzz sound and i am getting electricuted everytime I play and touch the mic and i have a strong feeling its...
You are looking at the WRONG end of the guitar cable. You have a VERY unsafe guitar amplifier OR the mixer that is connected to that mic has an UNSAFE grounding condition.
If your guitar amp is an old one that has a two wire cord and a switch you change to reduce hum, take it in to have a three wire power cord installed IMMEDIATELY. Only plug into grounded receptacles. This is needed to reduce electrical noise and hum but MORE importantly is personel safety.
If the problem is with the mixer and the electrical service to the mixer, better get a professional in to analyze the problem before somebody is injured.
AS A START do this: VERIFY that ALL interconnected equipment INCLUDING your guitar amp iis powered from the same source or receptacle. This includes the venue power amps, mixer, any CD players, etc. Professionals run power back from the stage source to the mixer alongside their snake to avoid just the problem you are seeing. When they need more power at a venue, a power distribution box is used that conditions the building power and insures grounding.
Mar 25, 2011 | Fender American Deluxe Telecaster
I have a spider III 15W amp that has worked for a year. plugged in last night and it's getting power but no sound. Not even a hum from the speaker. checked everything and it's definitely the amp....
Try disconnecting the speaker from the amp with the amp unplugged from your power. Never work on an amp when its plugged in unless you know how dangerous it is. Check for resistance across the speaker terminals with a volt ohm meter to see if you have a blown speaker. Thats the first thing to look for. You should here a hiss or a low hum when your amp is on and you plug a guitar cord into the input without the guitar. Check those two things first.
Jul 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Only getting running lights out of trailer plug
If you haven't already sprayed plug with penetrating spray or similar (WD-40) then do that first. Next, do yourself a favor, go to a hardware or autoparts store & purchase a 12 VDC test light. (about $5-$10) and it will be one of the best investments you ever made as far as tools go. With it, you can test for blown fuses bad wiring etc. Do you know where I'm going with this as in testing for power in those wires? Start at plug on car, if the power is that far, then it's the trailer side that's causing trouble. If no power at plug on car and your not sure how to proceed, get back to us. You did check for fuses under hood as well right?
May 25, 2009 | 2003 Oldsmobile Bravada
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
138 people viewed this question
 Grubhead
Grubhead
