Question about Electric Health & Beauty
My electric scooter"s batteries aren't lasting that long anymore. I've traveled 20 miles on a single charge. now... about 9 or 10. What can I do to fix it?
    Top Expert:
  • Electric Master
  • 52,175 Answers
Batteries get tired when they age ,nothing lasts forever
Posted on Apr 28, 2017
Victory 4 pride mobilty scooter,the charger dont seem to charge up the batterys. is the charger faulty.
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
CLICK HERE MANUAL
Aug 27, 2012 | Pride Go Go Ultra 4 Wheel Travel Scooter
Is there a battery replacement for my L4 that will give me a longer running time?
There isn't room onboad for bigger batteries. But you can cheat by constructing a two wheeled trailer just big enough to hold two more batteries they can be as big as you want. When the on-board batteries get low flip a switch and your running on out-board batteries. Be sure the trailor is conntructed to be as lite weight as possible. you can buy trailers for scooter. I did it the lazy way, I wired my external batteries directly to my internal battery terminals due to amp loading.If they are lets say 50amp to your 15amp on- board batteries you are going to go way more miles than with15amp batteries. WARNING this setup you don't hook fully charged big batteries into discharged small. batteries. I don't let my on-board batteries get to discharged. I've spliced into the main battery terminal lines..so that they are thick enough to handle the amp load which are 12 gage. I also have a 50 amp connector between the external scooter and the trailer for quick disconnect
Jun 08, 2012 | Invacare Lynx L4 4-Wheel Travel Scooter
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
Jan 21, 2012 | Health & Beauty
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
How long does the scooter charge generaly last?
You should be able to travel a couple of miles and return on a full charge. Of course the slower speed you select to use when you travel will increase the distance some. Hope this helps
Nov 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a scootamart large scooter,not sure if 6 or 8 mph.batteries have been checked and are perfect but can only travel 5 or 6 miles on a full charge.what can be wrong.
Hi. How many amp/hours are your batteries?
Who tested your batteries, and how did they test them.
I have had batteries tested by an auto electrical technician, who said the batteries were OK. I knew at the time that the batteries were faulty.
What he did was do a short high current test, that he would normally do on a car battery.
To test batteries in a scooter you have to do a constant current test on fully charged batteries, and monitor the battery voltage. When the battery voltage drops to 10.5 volts across the 12 volt battery, that is considered a flat battery. Take the time elapsed for the test, and you can roughly work out the amp/hour rating of your batteries.
The amp/hour rating of a battery is worked out on a 10 or 20 discharge. A 40 amp/hour battery can supply 2 amps/ hour for 20 hours.
If you take 20 amps per hour, you will not get 2 hours of use. You will probably only get 1.5 to 1.75 hours of use. The more current ( amps ) you take out of a battery, the less amp/hours it will supply.
The best way to test your batteries is a constant current test, but they take a few hours, or try new batteries.
Also how long do you charge your batteries for. Most chargers need to be on at least over night to fully charge your batteries.
Some chargers have a green LED that comes on when the batteries are nearly full. This green LED is a guide only, and most batteries still need a few more hours to do a full charge.
Good luck. Neil.
Jun 10, 2010 | Health & Beauty
WHAT ARE THE NEWEST AND LONG LASTING BATTERIES I CAN BUY FOR MY MOBILITY SCOOTER. I WANT TO TRAVEL FARTHER THAN THE 20 MILES WITHOUT RECHARGING THE BATTERIES. ALSO I WOULD LIKE THEM TO BE SMALL AND LIGHT...
Hi. When you are looking for good quality batteries, they will have a 1 year warranty on them. If you get offered only a six month warranty, don't buy them. Good batteries weigh more than cheaper batteries, because they have more lead in them.
To get a good distance, you need to fit the biggest batteries that will physically fit in your machine.
Batteries are designed to handle a certain number of "charging cycles". If you run a battery down by approx 75%, you will only get a small number of "charging cycles". If you only use 25% of the batteries capacity, you will get 100's of charging cycles.
Gel batteries seem to be the better choice. Most AGM sealed batteries are designed to be stand-by batteries. They will work fine in your machine but only for light use. I have seen these batteries last for 7 years, but only for light use.
Good luck. Neil.
Jun 02, 2010 | Electric Mobility Pacesaver Electric...
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Health & Beauty Logo
27 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
