Question about Sewing Machines
My wind machine suddenly stated running very slow now
My bobbin is winding really slow on my Pfaff Quilt Expressions 4.2. It used to wind fast and don't know what happened.
Hard to say.
Does it wind slow with both methods? I would double check that the thread path is correct--incorrect thread path could cause it move slower
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj8nPz_2qXYAhXSk-AKHTYIDQsQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AOvVaw00vbTPKaCOh98HQ2-QnKQP
You may find a standalone bobbin winder (Sidewinder for $30) avlb at JoAnn's or on Amazon. Nice little accessory that lets you wind multiple bobbins without unthreading the machine and also saves wear and tear on your machine.
Dec 25, 2017 | PfaFF Sewing Machines
Why is that my new home machine 641003843 takes so long to thread the bobbin?? It runs very slow when winding
hi Lori.
this is all i could find out so not sure if its any good to you.
  • Check foot control
  • Adjust speed control
  • Remove lint/dust from under needle plate
  • Check if bobbin winder is still engaged
  • or try this link out.
18 Common sewing machine PROBLEMS answered Easy fixes Sew Guide
Dec 13, 2017 | New Home Sewing Machines
My machine runs too slowly.
Consult your owner's manual for maintenance instructions. A computerized machine requires oiling only in specified areas. Use fresh, good quality sewing machine oil recommended by the manufacturer and apply one 1-2 drops each spot. Make sure your machine is clean of any lint or thread build-up, ie usually in the bobbin and feed dog area. If it continues to run slowly, might be a good idea to take it for service.
http://www.fixya.com/support/t8681532-sewing_machine_suddenly_slowed_down_its
Dec 17, 2015 | Brother CS-8150 Computerized Sewing...
When following manual directions to wind a bobbin, it starts out OK, but after several winds, the thread turns out with little loops on the bobbin. ??? Sylvia
Make sure that you are running the thread through the winder tension guide before it goes bobbin winder. Best to consult your owner's manual.
Also, it helps to slow down the winding process. Slower speed winds the bobbin more consistently and does not stretch the thread as much as a fast speed will.
Beginner Guide to Sewing Sewing Machine Parts Reference Guide
Nov 28, 2015 | Sewing Machines
When winding the bobbin, why doesn't the lever snap into place to detect when the bobbin is full?
Hard to tell since you didn't state the machine brand and model. But, with most machines, you have to manually snap the lever onto the bobbin before beginning the winding. As the bobbin fills, the lever will move until it snaps out and the bobbin winding will stop. Best to consult your owner's manual.
Aug 30, 2015 | Sewing Machines
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin winder has no tension
are you sure you have the thread over the right place? it should be from the spool to the small metal wheel on the top of the machine and nothing else, also make sure your using a janome or s-class bobbin ( also it should be a plastic bobbin if it loads from the top of the machine and not the front ) when i fill a bobbin i also start out slow sometimes keeping my finger loosley on the thread itself before it winds on the bobbin to give it more stability.
Sep 23, 2008 | Janome 8080 Computerized Sewing Machine
Sews and then slows down. will not thread bobbin
make sure you are running you thread around the bobbin to get it started start slow when winding, is there something under your sewing foot(on the floor) when you are sewing if it's slowing down sounds like something may be holding it back, only other thing that may cause something would be internally if not the feed dogs. let me know hope this helps amy
Jun 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
