Question about Moen Home
How to remove a shower flow restrictor from a Moen Model: 82910 Banbury
We could remove it with older models but not this new one.
3 Suggested Answers
  • 299 Answers
SOURCE: flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Posted on Apr 20, 2010
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
How can I remove the flow restrictor in the shower? I have terrible water pressure.
You need to tell us what shower head it is. Usually the flow restrictor is in the section that screws onto the pipe that goes into the wall. Be careful when you take it off so that you don't mar the chrome finish,
Aug 23, 2014 | Moen 7175CSL Level Single-Handle Kitchen...
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one...
were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
Sep 16, 2010 | Moen & One Handle Tub & Shower Faucet
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Flow restrictors
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
New House The women is complating that then she shower at any of her bathroom tub shower unit the faucet become cold for a little while on all her Moen chateau faucet. We have change all valve cartrige
The problem is most likely with "the back pressure from the flow restrictor in the showerhead causing the spool in the cartridge to sense a false pressure drop. This is forcing the spool to shift, restricting a full hot water temperature from coming out." Believe it or not, I got this information from Moen. Their solution was to send out a valve without the multi settings of the original and that didn't work very well. I can only tell you that I used an older showerhead without the water saver feature and the valve and cartridge worked fine. The problem your having is with the cartridge/showerhead combination and short of using an older showerhead there is not a satisfactory solution. Maybe your plumber has a better solution.
Dec 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
101 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
