Question about RCA Televison & Video
How do you adjust the color on a big screen tv model number d52w19 its an rca
SOURCE: I HAVE A OLDER MODEL RCA HOME THEATER BIG SCREEN TV
I have the same tv at my place and I got Sears to come over and fix it. It cost me ~$90 for the initial visit then I ordered ~$140 part he recommended (voltage thing for crt) ordered and installed. He said that if that didn't work then he would have been able to return the part and it would have been the circuit board going out and that would have cost around $400 more. He said that if that were the case it wasn't worth it since you can buy one of these tvs used for around $500. The part he ordered worked on my tv and is doing fine.
I have an additional question though: is this tv HD ready for when all the signals change next year?
Posted on Apr 10, 2008
welcomejee
  • 10594 Answers
SOURCE: RCA BIG SCREEN TV - COLOR PROBLEM
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
Posted on May 30, 2008
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
  • 1810 Answers
SOURCE: rca tv wont come on at all
there is an inherant problem with rca tv's
they are not vented properly as far as im concerned
right in front of the fly back is a small part in mine it is grey i think it's a resister
when i took the back off i saw that it was sparking on 1 end ( wholy chit ) scared the **** out of me
if your chip is sparking try this fix if not turning on or no pic look inside and look for burns vthere a tell tale sign of over heating
what i did was crazzy but it worked
i took the stupid chip off by pulling on it what the puck it was screwed any how
then took it to my local electronics store they tested it and told me it was fine just had to but a new 1 since i broke a pin on 1 end
nothing grinding down ends of the case and adding some wire to the pins so i had somthing to solder to
the i re soldered the thing back to the board dam thing was trickey but as long as you are smart and gentl and for god sake un plug the set there is 600 volts inside if not more that can kill you near this chip
it now works fine my 52 inch tv has cost me $7.00 in gas and about 3 hours of time
what i noticed was that the chip over heated at the solder joint and burnt the hole bigger so i soldered and wired to the next conection and re soldered it carefully i did not remove or un plug any thing i just remeoved the board from it's slide mount and carrefully tiped t of only poping 2 conections witch were easy 2 put back on the tv is great it just hates running for 6 monthes at a time hell you shut off your $500.00 computer every once and a while dont you ???
then why would you not shut off your 2000 dollar tv every day
well hope this helps all or at least some of us who cant afford a high priced repair person to show up and tell us it will be 3-400 to fix but they will give us 50.00 for the old chasie and fix it and re sell it for 500 in a refurb tv store like factory direct in canada
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on Jun 07, 2009
Sony projection tv has only blue color and power light is flashing 5 times
Google the model number if sony with 5 blinks--you have it posted here as a rca set.
Apr 30, 2012 | RCA D52W19 52" Rear Projection Television
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
http://servicemanuals.vstore.ca/
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
Projection screen rca tv picture need to be relined
There a kit for that symptom on your model Leave an email at the following link stating your model number and what the symptoms are you can repair it for under 20.00 and they provide the oarts and instructions on how to do the repair. Heres the link.
Jan 26, 2009 | RCA D52W19 52" Rear Projection Television
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
Replacement screen for RCA d52w19
You will need the entire model number to see if the screen is avalible.. D52w19 + the ext number YX1 or yx2 or something like that it will be on label as model number but in smaller letters.
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
RCA Model D52w19
One thing that comes to mind is the two main connectors on the power/deflection board. They have ribbon cable in them. If they are white in color. One of them plus the one on the convergence board that is the same size, needs to be replaced. If they are black they are good. Part number is 258686. If your serial number is between G13XXXXXX and G26XXXXXX this is a very good posibility.
Aug 04, 2008 | RCA HD52W58 52" TV
Off color
hummm i wonder if you may have lost one of your projection tubes... like red or blue.. that would be my first instinct and i would have to remove or at least get the screen loose enough to see if all tubes are lighting. tube replacement on these are somewhat difficult and expensive. 250 just for the part and prob another 250 for labor. but if its not the tube it could be screen control adjustment of focus pack.. so here hopeing.. Willie@fordtv.com
Mar 01, 2008 | RCA D52W19 52" Rear Projection Television
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
