What settings do I use to use an antenna on a Wd60638
I have Mitsubishi dlp WD60638. It will not turn on at all. There are no lights blinking and no sound is coming from the tv. Any ideas, or should I just purchase a new one.
This sounds like you have blown the fuse protecting the power supply. The cost of analyzing and fixing the problem will go a long way towards a new TV. The newest LED-backlit LCD sets with local dimming are much better than the older projection TVs. They are brighter, sharper, and provide better blacks. I know which way I would go.
Aug 23, 2016 | Mitsubishi Televison & Video
My WD60638 has a couple of white dots on the screen, what causes this and how can i fix the problem
if its a dlp tv most likely the dots are from.the bulb if its an lcd tv your screen may not be of high quality u need to change it
Oct 02, 2015 | Mitsubishi WD-60638 DLP TV
I recently bought a model wd60638 tv which the previous owner had just changed the lamp. I have noticed a black looking smear on the lower right side of the picture screen.
YOU MIGHT DEGAUSSING YOUR SCREEN. I ALSO SOUNDS LIKE YOU MIGHT HAVE A SMEAR OF SOME SORT ON THE SCREEN SO SEE OF YOU CAN WIPE IT OFF. GOOD LUCK.
Jul 01, 2015 | Mitsubishi Televison & Video
How to mount cb antenna in a tree
alright you came to the right place.My wife doesn't want an antenna on the house so I stuck it in a tree. Here goes. First you nedd to get up in the tree as high as you can without falling or breaking any branches.This is how I did mine. My son and I got up the tree and set an antenna l bracket into the tree to set the antenna on. Then we set the antenna on it and secured it with metal strip banding ( you can get it at Lowes or home depot) About 2ft from the bottom of the antenna attach one end of the band to the treeand wrap it around the tree crossing over the bottom of the antenna. Now move up about 4ft and attach another band in the same manner you did on the bottom. Make sure you have enough coax and connect it to the connector on the bottom of the antenna . Connect the radio and you are set to go. that simple
May 29, 2015 | Solarcon Antron 99 CB Base Antenna - A99
Have a wd60638 changed the lamp because old one busted now the TV works fine for about 3-5 minutes starts to hum and a clicking sound and pictures begins to flicker with colors going in and out
normally no bulb will bust ever unless you have oil on the lamp. sooo , it got too hot then. even if the fans turning its not putting out.
check the exhaust it should blow a lot of air past the lamp.
Oct 19, 2014 | Mitsubishi Televison & Video
How do i reset my WD60638
This model will or may have the soft reset: power on, menu 1,2,3 enter.
It will have a hard reset that requires a 4 digit number code as well that is available only from Mitsubishi or a authorized service center---they do not want that made public as one wrong move......
Oct 30, 2012 | Mitsubishi WD-60638 60-Inch 3D-Ready DLP...
Setting up antenna to television
For setting it your set you will have to connect the antenna to the back of set.
Go into the setup menu to select the input signal source.
Set the signal input to the antenna air.
Go to the scan section of the setup menu.
Scan in the channels. You can move the antenna and re-scan to try to get more channels.
Exit menu.
Now you can watch.
Feb 10, 2011 | Soyo GVNL3768AB 37 in. LCD Television
I can't seem to get any digital channels
Before scanning for channel, check to see if the Antenna input is set to Cable or Antenna. If you have rabbit ears or and outside antenna then set it to antenna. If you have cable then set it to cable. Then rescan for channels. If this has already been set then the next step is to check the antenna or cable feed. If possible plug the antenna or cable feed into another TV that is known to be working correctly. If it is capable of receiving digital channels then the problem is likely the Samsungs ATSC tuner and will require service.
If neither TV is getting Digital channels then I will need more info on your antenna setup and where you are located. I am a pro on TV antennas and reception.
Hope this helps
Have a great Day
Mar 31, 2010 | Samsung SyncMaster 2333HD 23 in. LCD TV
I do not have cable television. how do i find the antenna? is thee an antenna?.do i find an antenna by utilizing the emote contol?
hopefully you have an antenna connected to the set first , then go into the menu and look for your setup on installtion and run auto tune or scan set to air and let it run but remember youneed to have a good antenna connected to the set
Dec 04, 2009 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
