Renco cable coverter how to unlock the channel
Bought 42in Philips SmartTV from Singapore and used in Philippines, attached to cable but reception is rainy. i tried to connect a renco digital converter, got sounds but black screen on TV. Pls help.
Sound like you HDMI settings is not set right. put it back the way you had it so you can change different setting for you HDMI.. like 1080i or p or ip or 720i or p or ip...
Maybe that will help
Good luck.
Apr 24, 2015 | Philips Televison & Video
Renco remote how to reset tv channels
On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels. Press off again then 0 for about 12 times then 2 to restore all VHF channels.
Jul 13, 2014 | Televison & Video
Renco tv cable converter channel loc how to remove
1) On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels.
2) Press off again then 0 for about 12 times then 2 to restore all VHF channels. This will also remove the Lock of channels.
Nov 17, 2013 | Televison & Video
Do you have a user manual for a renco cable converter remote?
Jun 06, 2012 | Televison & Video
Just got my 32" and am not clear on whether it can be connected directly to cable wire or if it has to go through the converter box. Thoughts?
Yes it should be fed through the coverter box, otherwise you'll not be able to get any digitally enhanced channels. If it is HD you definately need to use the converter/cable box.
Aug 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Nov 30, 2008 | Insignia Digital-to-Analog Converter for...
Digital coverter box
YOU WILL ONLY NEED A CONVERTER BOX IF YOU DO NOT SUBSCRIBE TO CABLE OR SATELLITE SERVICE AND RECEIVE YOU CHANNELS THRU A REGULAR ANTENA. YOU WILL NEED THIS BY 02/2009. HAVE A NICE DAY.
Mar 19, 2008 | Toshiba MD13P1 13 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
