How to remove the lock channel - Televison & Video
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
All channels are locked out how do i un lock them
To remove the lockout from a channel, manually select the
channel and press L/OUT so LO changes to lo.
reviewing locked-out channels
To review all locked out channels, press MAN. Then repeatedly
alternate between pressing FUNC and then L/OUT to view each
locked-out channel. When you fi nish reviewing locked-out
locking out frequencies
To lock out a frequency during a search, press L/OUT when the
scanner stops on that frequency. The scanner locks out the
frequency, then continues searching.
From the manual:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
Please remember to rate my solution.
Jul 03, 2011 | Radio Shack Pro-97 Handheld Scanner
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
Power window
REMOVAL & INSTALLATION
R/V Series
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the window control bolts and lay the control aside for access.
  5. Remove the regulator-to-door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION The next step must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 / 2 in. (13mm) to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 / 4 in.) in the drilled hole to lock the sector gear in position.
  2. Remove the motor-to-regulator attaching screws and remove the motor from the regulator.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
C/K Series
  1. Disconnect the battery ground cable.
  2. Remove the door trim panel.
  3. Remove the water deflector by peeling it back.
  4. Disconnect the door lock rods at the module.
  5. Loosen the upper run channel bolt.
  6. Move the run channel away from the glass.
  7. Pull the wiring harness towards the door to reach the connector. Remove the boot from the wiring and disconnect the harness at the door hinge pillar.
  8. Remove the module and window assembly from the door frame by tilting it and lowering it from the door.
  9. Fold back the tab on the channel and slide the glass out.
  10. On trucks with power components, drill out the rivets from the inner handle housing.
  11. Drill out the regulator assembly rivets.
  12. Remove the regulator/motor assembly.
  1. Install a pan head sheet metal tapping screw through the sector gear and backing plate in the hole provided, to lock the sector gear in position.
  2. Drill out the motor-to-regulator attaching rivets and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the replacement attaching bolts and nuts.
  4. Reposition the motor/regulator in the door and install the wiring connector.
  6. Slide the glass out into the channel and fold over the tab.
  7. Fit the glass into the rear channel in the door, then, while pulling the channel towards the glass, fit the glass into the front run channel.
  8. Install the boot from the wiring and connect the harness at the door hinge pillar.
  9. Install the lower run channel bolt.
  10. Install the door lock rods at the module.
  11. Install the module panel screws, starting at the top left, then the top right.
  12. Install the water deflector.
  13. Tighten the upper run channel bolt.
  14. Install the trim panel on the door.
Jul 30, 2010 | 1994 Chevrolet G20
Pressing L/O on my BC60xlt does not remove lock out.
To restore all locked out channels press MANUAL to stop scanning, then press L/O - and hold the key in for at least 2 seconds.
If a channel is showing all zeroes (000.0000), the only way to remove the lockout on it is to program a frequency into that channel.
Bill B
Apr 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
