Code E1 keeps coming up - Heating & Cooling
E1 keeps coming up on my machine and the press or foot is very hard to lift
Check the troubleshooting section of the manual for error codes or search for:
Make Model error code E1
Apr 27, 2018 | Sewing Machines
Elite 10 qt pressure cookercode E1 keeps. Coming up on panel on front of pressure cooker. It went heat up at all
try contacting the manufacturer through their website. most have tech support these days
Nov 21, 2016 | Kitchen Appliances - Others
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
Haier washing machine keeps stopping and displaying error code E1
As said in the question you are haier washing machine keeps stopping and displaying error code E1 this is due to the Error signal due to Pr. Sensor.This problem can be solved by only service Engineer.Thanks for your question.
Jun 20, 2011 | Washing Machines
E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 28, 2010 | Tunturi T30 Programmable Treadmill
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
