How can i trouble shoot polaroid 42 flat screen sound but no picture
I was told about 4 switches in the back, but cannot find this newer model
  • 71 Answers
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
  • 8457 Answers
SOURCE: No sound on my Polaroid flat screen
Unplug,replug the tv about an hour later.Go in ur tv menu.Go to AUDIO,go down to reset it,well go back to factory setting.Ur sound should return.Not,than ur Tuner board is dead.Trires websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacenent.
Posted on May 04, 2010
rulds2008
  • 3866 Answers
SOURCE: We have a works 42" Polaroid with sound but no picture
The common issue with polariod is there power supplies, Your going to have to fork out something for the repair if you not willing to buy a new TV here, A new board in this would be $175 labor another $80 or $90 tops. So you getting into $250 fast. This is why I say to all my askers NEXT TIME buy a extended warranty. This will need a new power board sorry to break it to you and its the common issue I am seeing on fixya.com from my premium chat customers. Please do be considerate as this information was free to leave postive feedback and maybe a ranting or two.. for all those expert involved in your case today.
Posted on May 29, 2010
budmrtn
  • 11361 Answers
SOURCE: My Polaroid Flat screen has no picture, but still
No picture can be caused by dead T-CON board, main board, 24vdc power supply not supplying power to the backlights inverter board, bad backlights inverter board. So inspect for bad caps fisrt and also try the instruction below.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 18, 2011
  • 184 Answers
SOURCE: no power light,no sound no
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
but if otherwise, There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
This will require you having basic knowledge in electronics repairs and do take care in handling the power supply of the television..
I hope that will help
Posted on Aug 05, 2011
I have a 40 or 42 inch flat power comes on but no
bad bulb? How old is it? if not really new it could be the bulb read your manual to find out what the blinking lights are telling you. They have a code set up to trouble shoot them.
Aug 20, 2013 | Polaroid Televison & Video
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture but there is sound
think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 10, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
I have a 42'' polaroid. no pic no sound
If you replaced the metal box located on the backside of unit and nothing changed. Send it back for a refund because your problem is most likely the video control board located top center of panel. If you replace that and problem remains its the panel.
Jul 08, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Jun 22, 2009 | Polaroid FLM-4201 42 in. LCD Television
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
No picture, good audio. Replaced motherboard...
Feb 12, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
