Question about Garden
The tractor jd 5103 with512 loader - Garden
SOURCE: Hour Meter not advancing
The connection should be on the back of the meter. You'll need to get behind it and probably remove it. There should be a bracket with a nut/screw attaching it to the back of the meter.
Take a look at this and let me know what you find.
Posted on Apr 28, 2009
Mackmech11
  • 122 Answers
SOURCE: jd tractor 11hp briggs engine has no stark
I would check the stator which is located on the top or side of the motor, this is what produced spark and if there is rust on it it will lose spark. so basically remove the fan housing the top of the motor and you should see it either on top or directly on the side i believe it has one wire going to it green in color and is held down by two bolts. good like look out for the rust
Posted on Apr 18, 2010
Biggdex35
  • 333 Answers
SOURCE: Tractor Front end loader will not dump
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
Posted on May 11, 2010
wireguy212
  • 1627 Answers
SOURCE: JD 301 industrial loader tractor Overheating
You may need to do a compression test on the engine to confirm whether or not the head-gasket needs to be replaced,that's where i would start if the thermostat is not the problem and the hydraulics are not loading up.Check for oil in the radiator or anti-freeze in the oil as well as for white smoke out of the exhaust,all are indicators of a bad head-gasket.
Posted on Jul 18, 2010
franklembo
SOURCE: JD mighty mover tractor, 27MHz,
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Posted on Dec 10, 2012
A WING ON THE JD 15' MOWER WILL NOT LOWER. ANY IDEAS?
Just an idea but my guess is that it is in the hydraulic system.
Probably a safety valve that prevents it from falling in case of a hydraulic line break.
Link to JD answer center.
Answer Center from JohnDeere
Sep 09, 2014 | Garden
What year is a john deere 125 skid loader with serial 10275
Call your nearest JD parts agent or JD direct. If you want a free owners manual go to deere.com there is one for 60,90 and 125 loaders on download.
Aug 15, 2014 | Garden
Hyd problem with JD tractor
Crack your hoses on cylinders to get air out of them.
Feb 06, 2014 | Garden
Jul 17, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Tractor Front end loader will not dump. JD 2320 tractor front end loader .
See if its that
May 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Apr 28, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
