Picture goes out but still has sound,tv is still farley new
Crt tv sound ok but picture goes on & off
try checking the tv/av tact switch,if it is grounded or normally close or has a resistance with pressing, replace it with a new tact switch..
Jan 03, 2014 | Samsung Televison & Video
RCA DLP tv, the picture goes blank after a few minutes, and then comes back on and goes back off again...
Take it back to the store. If warrenty is expired then you will have to get a new TV or send it for repair . I don't know of anyone that comes to your home for TV repair. Sounds like picture tube is out of it.
Aug 17, 2013 | RCA Televison & Video
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
Picture and sound go out and remote isn't working properly
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
May 28, 2009 | Mitsubishi WS-55515 55" Rear Projection...
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
