Is there a way to adjust the color from the back of the tv
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
What are the best color settings for a toshiba 40rv52u
saultoman,
First set your picture setting back to their defaults. Now adjust each setting up and down all the way to learn what they do.
Then try the following:
1) Leave your back light at 50%.
2) Adjust the brightness until blacks look jet black them back some.
3) Set the sharpness up until it looks like too much then back a bit; you can never have too much.
4) Add only a little color as most people like a little more color than what the TV is set to show.
5) Now adjust the contrast up until it no longer looks as if your are watching TV with sunglasses on; don't be afraid to go to 100%.
6) Now work the back light only a a small amount.
It can take some people a few days to tweak the settings. Remember to right down each setting on there value for future reference after getting the picture to what you like.
-Chris
Sep 11, 2010 | Toshiba 40RV525U 40 in. LCD TV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Color projection tv
Adjust the top left knob back down till the color comes back
Feb 25, 2010 | Philips Televison & Video
Trying to adjust my Philips TV's Custom Color Temperature
Philips 32PFL3403/12 problem with colours, after 1 hour working: starts to mix colours.
Feb 20, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Lost color sync
sounds like you have a convergence problem. replace the 2 convergence chips STK 390-110.
Feb 04, 2007 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
