Utica Boiler UB95M•200
I keep getting E 04 message. I hit reset. it cycles 076, 176, then 276... then back to E 02 or E 04 I've cut power to it, and rebooted it. Any ideas?
  • 37 Answers
SOURCE: boiler leak
Hi, it appears you have a defected relief valve. you can try one solution. lift the handle on the relief valve and let some water out. sometimes that can flush out materials thats blocking the stem in the valve. if it's still leaking it must be replace.
If this doesn’t work for you please write back. Thanks,
Posted on Nov 23, 2008
  • 14 Answers
SOURCE: continuous reboot problem
Most likely, if your unit is not powering up to the TiVo Central screen, you have a hard drive problem. You might consider a replacement TiVo hard drive.
Posted on Nov 04, 2009
  • 82 Answers
SOURCE: I have a Utica boiler pilot is on. instaled in 1990
Check the gas valve on the boiler. See if it is on the "pilot" setting. Sounds like it is....if so, turn to "on"
Posted on Dec 31, 2009
walterkunesk
  • 683 Answers
SOURCE: My boiler keeps cutting out
try turning the power off the boiler and turning it back on, let me know.
Posted on Feb 20, 2011
  • 127 Answers
SOURCE: My 1998 Cabrio engine keeps
Fuel pressure problem, O2 does not send info to ECM during accelaration so cant be that, catalytic converter doesn't cause check engine light to come on, try changing fuel filters
Posted on Mar 22, 2011
St 9400c keeps cutting out and turning on rapidly boiler will not heat properly
rapidly? seconds or minutes.
Make sure you select hot water boiler in the thermostat setup. That can cause short cycling. Boiler need a longer cycle range. If not, remove stat and jump wires, Isolate the problem, is it stat or boiler?
Sep 23, 2014 | Heating & Cooling
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
Chime
power cycle the system then hold star and pound that is a back door into programming hit #20 that will tell you the installer code then hit *99
once you have the installer code hit (Installer Code + 5 + 0) if you want to change the master code hit installer code + 8+02+new code + new code to create a new code
May 16, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
Nov 09, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Boiler leak
Nov 23, 2008 | Watts 3/4 Pressure Relief Valve
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
