Question about Sage Computers & Internet
I need the lead wires that goes from machine to the pads better show the complete kit model AT6717 this is for ICIA Electro Sage 8
Good morning,perhaps I should elaberate a bit further upon my already sytated problem.
Try to find a replacement. If not have a service center with a schematic make a new one.
Dec 05, 2014 | Alesis Music
Need serial and activation key for sage 50 2013
So get in touch with Sage at www.sage.co.uk/50Accounts2013
Feb 10, 2014 | Sage 50 Complete Accounting 2013 -...
Instant Accounts 8.0 (013604ug): I am using Sage Instant Accounts version 8 and am ...
Hi.
We had same problem. Our solution:
1. Empty both the 'accdata' and the 'criteria' folders.
2. Start Sage.
3. Restore a previous backup.
This worked for us. Hope it helps you.
May 17, 2010 | Sage Instant Accounts 8.0 (013604ug)
Sage sbd platform installation update has stopped working
To download the Sage SBD Desktop Installer Utility (Build 111)
Access the Updates page on the Sage website: http://www.sage.co.uk/support > Downloads > Updates.
Note: You must log in to view this page. To do this, click Log in, enter your email address and password for the Sage website, then click Log in.
From the drop-down list, choose Line 50 & Sage 50 Accounts then click Go.
Locate the Sage SBD Desktop Installer Utility (Build 111) then click Download.
From the File Download window, make a note of the file name, for example, sbddesktopbuild111.exe, then click Save.
From the Save As window, browse to the required destination, for example, your Windows desktop, then click Save.
The Download window appears showing the progress of the download and the estimated time to complete.
Once the download is complete, if required, click Close.
You have now successfully downloaded the Sage SBD Desktop Installer Utility (Build 111). For instructions on how to install this, click the Install it tab.
Mar 23, 2010 | Computers & Internet
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Where does the wire go off the points?
wire goes to the coil.condenser lead is attached to the same connection on the points.
Oct 01, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
Multiple paper feed with 5L
You need a separation pad kit for your machine. The parts are relatively inexpensive. There are 2 ways to accomplish the fix. You can install a separation pad overlay kit which can be done without disassembly which is simply adding a peice of rubber over the existing pad or a complete roller & pad kit which requires disassembly of the machine. The easiest is the overlay however best and longest fix is the full kit replacement. Here's a link to each of the kits off of ebay.
Overlay Kit: (5 minute install) Approx. $10.00
http://cgi.ebay.com/HP-Laserjet-5L-6L-3100-3150-Jam-Repair-Kit-Feed-Fix_W0QQitemZ230300272758QQcmdZViewItem?hash=item230300272758&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Full Feed Replacement Kit: (30 minute disassembly required) Approx. $25.00
http://cgi.ebay.com/HP-LASERJET-5L-6L-3100-FEED-JAM-REPAIR-KIT-VIDEO-8-PCS_W0QQitemZ120319146203QQcmdZViewItem?hash=item120319146203&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Here's a link to a fre service manual for the machine just in case you get into difficulties:
http://www.feedroller.com/Store/Service%20Manual/LASERJET%205L,%206L,%206L%20Gold,%206L%20Pro%20Service%20Manual.pdf
Hope that helps you. If so please rate me with a FIXYA!
Oct 19, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
ray gallant
richie46
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
