Question about Troy Garden
How to adjust blade on my troy bilt mini rider its 1 1/2 out of level side to side?
5 Suggested Answers
mickey813
  • 472 Answers
SOURCE: adjust brakes parts/schematic for troy bilt super
ON THE SIDE OF THE TRANS THAT 1/2 INCH NUT TURN IT TILL IT STOPS THEN BACK IT OFF 2 TURNS
Posted on Oct 02, 2009
  • 36 Answers
SOURCE: I need to replace the blades on my Troy Bilt 46"
If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
Posted on Aug 18, 2011
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
timblodgett
  • 691 Answers
SOURCE: Troy bilt 26J Mini Rider clutch sticks. How do I adjust the tension?
the pully midway from engine to deck. Look for an adjustment where the pulley articulates with the foot control. The pulley probably moves to provide adjustment control
Posted on Sep 28, 2015
Troy bilt rider won't start after filling fuel and blowing off deck. Won't even turn over even though in neutral and park. Blades are up
be sure that the connections on the safety switches are still hooked up. and the blades are in the off position. don't make much sense. this is one where you are going to have to track it down. start with the battery connections. safety switches, grounds. it is there just have to find it. check and be sure the fuse isn't blown.
Aug 14, 2016 | Troy Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Sep 28, 2015 | Troy Garden
How to change blade on a troy-bilt mower model 12a-264u011
Turn mower on it's side with the carb facing up (otherwise fuel will pour out of the carb) There should be one bolt holding the blade on, remove it and the blade will come off. Install new blade in reverse order. Use an impact wrench if you have one otherwise use something to keep the blade from rotating when removing the bolt with a wrench.
Oct 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Why does my Troy Bilt Pony Mower deck keep running after it is disengaged
-The belt is too tight. It should be free when the engine is running.
-Adjust it. It'll take care the problem. (I'll say it'll need about 3/4" to 1 1/2 clearance)
Good luck
mai
Sep 01, 2014 | Troy-Bilt Garden
I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Jul 26, 2011 | Troy Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Adjust brakes parts/schematic for troy bilt super bronco rider mower
Sep 05, 2009 | Mtd Garden
Garden Logo
19 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
