Question about Lands Phones
SPEAKER DOES NOT WORK ON DTERM80
WHEN I MAKE/ANSWER THE PHONE (NEC DTERM80), USING THE SPEAKER BUTTON NOT LIFTING THE HAND SET, THE PERSON ON THE OTHER END CANNOT HEAR ME. THIS JUST HAPPENED OVERNIGHT
SOURCE: can't hear caller
I expierenced the same problem with my V265 phone. First, note that performing this repair as I did will most likely void any warranties on the phone, and also is an electrical shock hazard. This repair should only be performed if the person/s performing the repair understand these risks and have at least basic technical knowledge in circuits, electricity, and audio. I take NO RESPONSIBILITY for damage or injury in any way, shape, or form. Please to prevent errors or any more damage, read directions fully before starting this repair. - Remove the Battery and make sure no chargers, headsets, etc., are currently plugged into phone. - Remove the housing on the phone which is on the same side of the camera and the external display by gently and carefully prying, making sure not to break the latches or any of the external parts. - Using a Torx bit (I believe it was either a T15 or T20 I used but not sure) or a small flat head screwdriver, remove the 4 screws holding down the board. - Now examine the speaker located at the earpiece of the phone and the two contacts which are on the board you just removed. Look to see if they were properly alligned and if contact is being made between the speaker and the board. (a PINK pencil eraser works great as a cleaner for circuit board contact points) - If contact is being mad and no obvious obstruction is found to prevent contact with the two, the easiest way for me was to take a speaker from another phone, and using it in place of the old one. (If you are willing to use extra time, you could also try finding an actual replacement from a manufacturer.) - I used a speaker from a motorola phone which was actually a few years older than my V265. - After finding a replacement speaker, you'll need to use some trial and error to properly allign it with the contacts on the board and to make it stay in position during everyday use. - For my V265, I had to use a razor and shave away the plastic molding which held the old speaker in place. Then use a VERY small amount of super glue to hold the speaker in position. Then I used a little bit of hot glue to give it some flexible strength. All together, it took me about 1 hour to complete this task and start using my phone again normally. - If any additional assistance is needed, feel free to e-mail at spike8551@comcast.net leaving your name and prefirably a phone number and best time to call, as a return contact. This will make it easier for me to help the best I can. Thank you and good luck.
Posted on Dec 21, 2006
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Posted on Apr 22, 2008
SOURCE: Can't hear each other
go to the setting on the handset -> advanced-> reset
I think the default pin is 0000
It will restart. I had the same problem and find the solution on line somewhere else
Good luck
I hope it works for your handset
GAREEM
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
Posted on Jul 28, 2009
  • 14 Answers
SOURCE: I have a NEC Dterm80 I need to program a button on
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Posted on Nov 17, 2009
Nec dterm80 how to keep the voicemail from
Check the controls window and recheck your settings. Set as you like.
Oct 03, 2013 | Mrv new 8000 40 port term server dc power...
Need to change the date on a NEC Dterm80 phone. Feature 9#hold didn't work for me. I normally use the Speaker - 728 - to change the time.
Feature 9# has to be done fromt he Admin phone. Somewhere on the system there is a phone that is the Admin phone.
Feb 23, 2010 | NEC Dterm DTP-2DT-1 Phone
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I have a NEC Dterm80 phone system
you need to program call forward all to outside number
speaker, dial 42, enter 9 plus phone number
speaker
it must be allowed in class of service though
Apr 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Nov 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80- I need to change the date
On the adminstrator's phone (usually ext 100, 101, 110 or 10)
Do not lift handset
Press the FEATURE button
Dial 9#
Enter the hour & minutes (ex:01:25) using the dialpad
Press RECALL button to change AM/PM setting
Press HOLD to change the calendar setting
Press FEATURE button again to save & exit
Hope it works for you
Nov 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Jan 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80 Phone
I have the feature button blinkin and i think the do not disturb is on help.
Mary
Nov 24, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
