Question about Dewalt Drills
I have DeWalt 14.4v XR. Turned torque ring to drill mode in 2nd gear. Used drill. Now I can't move torque ring back to driver settings.
  • 313 Answers
SOURCE: Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Posted on May 24, 2008
  • 313 Answers
SOURCE: Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Posted on Jul 06, 2008
stug_57u
  • 99 Answers
SOURCE: dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: torque ring stuck in hammer on my dewalt dc935
remove the spindle housing ,turn the collar spindil, if i d'ont turn replace 629828-00 spindle & clutch assy.
if i turne check the transmission 613237-00
Posted on Feb 16, 2009
SOURCE: i have a dewalt dc925 combi drill the chuck keep
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part $of the drill. Then pull it apart. The transmission comes in a one piece cassette. Insert it, and put the front back on and tighten the screws.
Posted on May 10, 2009
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Feb 01, 2012 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
Type your problem for a solution...
I'm answering without knowing which model you have but, there are some Dewalt drills that will go into hammer and/or drill mode only if the speed selector is in 2nd gear. The torque settings are accessable only in driver mode. Short of that you may have broken parts in the transmission that can only be repaired by replacing the transmission.
Dec 28, 2011 | Dewalt Drills
I bought a new dewalt hammer drill and i love it but when you use the number 1 speed it just clicks and smells hot once and a while it will work and when it works it works good its just getting it to work....
Hello. In the gear mechanism they use planetary gear set to get the torque they need to operate this hammer drill. What has happen is the gears are made of heavy duty type of PVC. Why, some how it strip off the teeth on some these gears and the only thing is work is electric motor moving broken gear around in that planetary gear housing.
Take it back where you bought this Dewalt drill and ask for a replacement. GB...stewbison
Sep 09, 2011 | Dewalt 18 Volt Compact Drill Kit
Dewalt xrp stuck in hammer mode cant move selector to drill or number selections
I am assuming you are talking about not being able to move the "Mode Control Collar" and unless you can get it out of hammer mode, you will not be able to change the torque collar either.
If you feel comfortable taking it apart AND its no longer under warranty, my best guess without seeing the tool will be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Apr 29, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
How do I select torque setting?
the black ring behind the chuck, has numbers on it, turn to desired torque
May 24, 2010 | Dewalt DC750KA Heavy Duty 3/8'' 9.6V...
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops. might be a gear problem? How do i fix?
These tools have panetry gearboxs to give maximum torque foe lightweight gearing. A common problem with the older DeWalt drills was the gear selector legs coming adrift. This is (potentially) an easy fix. First of all, the obvious stuff. Remove the battery and press the trigger to release any static/stored power. Undo all the screws and seperate the two halves. Try to keep all the internals in the back half like this... http://lib.store.yahoo.net/lib/mendingshed/DW958mainimage1.gif
Now check the metal legs coming down from the gear selector slide. They should be sitting through the sides of the gearbox, and located into the sides of a ring gear. They used to pop out of this gear which would stop it being pushed fully into position.
Nov 23, 2009 | Dewalt 18 Volt Compact Drill Kit
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Torque ring stuck in hammer on my dewalt dc935
Nov 16, 2008 | Dewalt 18 Volt Compact Drill Kit
Jul 03, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
83 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
