Question about Kenmore Kitchen Ranges
Identifying my Kenmore gas range which no longer has the sticker near drawer.
Cannot get the broiler drawer completely of my kenmore gas range #790.70603013 so I can replace the ignitor
There is a way..... If you pull the drawer out as far as it goes, you may find small plastic levers sticking out of the rails. Press 1 side up, and 1 side down, and you can pull the drawer out the rest of the way. In others, you can pop the drawer up and off the rails, so you can get into the brolier drawer.
Apr 26, 2015 | Kenmore Kitchen Ranges
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
As an alternative, please post a clear picture of the control panel.
Oct 20, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
I have a Kenmore Gas Range Model #75571691 - i think. That number seems longer than these other posted numbers - anyway - when i turn on the oven i constantly hear this puffing sound, it i turn on the...
That sounds to me like a weak bake igniter and its fairly easy to replace. The model number you provided is only a partial one look on either the door rim,behind the storage drawer,or inside the side panel with the storage drawer pulled out and find EXACT model# from the label,reply with it and i'll give you the part number for the igniter and instructions of how to replace it
Gene
Aug 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I need to find a conversion kit for my kenmore 790 range to switch from propane to natural gas. Where do i find it?
Most Kenmore ranges ship with the NG to LP conversion kit attached to the range. The conversion kit and instructions are in a bag and should be tied to the back near the regulator or behind the storage drawer. The installer who did the conversion was supposed to put the kit back with the original orifices in the bag.
If you do not have the kit, try looking for the manual at http://www.managemyhome.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu and ordering the conversion kit from http://www.searspartsdirect.com/ .
I hope this helps.
Aug 26, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do you light the pilot light for a 70 series Kenmore dryer?
MOST modern appliances that use gas ignition (including kitchen ranges) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the burner assembly functions are nearly identical, as well as, the type igniters used. If you are having ignition problems it may be a simple matter of a weak or bad igniter. The burner assembly will ignite automatically as long as the gas valve, igniter coils and igniter are all functioning properly. It can take up to 90 seconds for the burner to ignite. As the igniter ages, you may experience longer ignition times.
You can view an illustrations of your burner assembly at appliancepartspros.com, pcappliancerepair.com and searspartsdirect.com. If either of the igniter coils are determined to be defective, BOTH should be replaced at the same time. If you need assistance in troubleshooting the burner assembly components, or help identifying parts, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening. I hope this information is helpful to you.
May 25, 2010 | Kenmore 700 6972 Dryer
Hello where will i find my serial number on the rangemaster 1100 leisure model
Remove the drawer and the sticker will usually be on the right hand side of where the drawer goes in.
Nov 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Where can I find the make and model number of my Kenmore gas stove?
Usually down where you pull the drawer out below the oven door on a small business card size panel. If not check the back and on older stoves they can be under the top if the top raises up easily for cleaning.
Sep 21, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Kitchen Ranges Logo
27 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
