Question about Dewalt Drills
I have dewalt 14.4v XR. I turned torque ring to drill setting in 2nd gear. I used drill, now I cant turn torque ring back to 1=15 settings for driver mode.
  • 313 Answers
SOURCE: Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Posted on May 24, 2008
  • 313 Answers
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Posted on Jun 08, 2008
  • 313 Answers
SOURCE: Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Posted on Jul 06, 2008
stug_57u
  • 99 Answers
SOURCE: dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
Posted on Oct 26, 2008
rowdy45176
  • 2176 Answers
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
Posted on May 24, 2009
Can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
Jun 01, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Feb 01, 2012 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
Type your problem for a solution...
I'm answering without knowing which model you have but, there are some Dewalt drills that will go into hammer and/or drill mode only if the speed selector is in 2nd gear. The torque settings are accessable only in driver mode. Short of that you may have broken parts in the transmission that can only be repaired by replacing the transmission.
Dec 28, 2011 | Dewalt Drills
I bought a new dewalt hammer drill and i love it but when you use the number 1 speed it just clicks and smells hot once and a while it will work and when it works it works good its just getting it to work....
Hello. In the gear mechanism they use planetary gear set to get the torque they need to operate this hammer drill. What has happen is the gears are made of heavy duty type of PVC. Why, some how it strip off the teeth on some these gears and the only thing is work is electric motor moving broken gear around in that planetary gear housing.
Take it back where you bought this Dewalt drill and ask for a replacement. GB...stewbison
Sep 09, 2011 | Dewalt 18 Volt Compact Drill Kit
How do I select torque setting?
the black ring behind the chuck, has numbers on it, turn to desired torque
May 24, 2010 | Dewalt DC750KA Heavy Duty 3/8'' 9.6V...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
I have an 18v dewalt hammer drill dc925 and cant get it on the hammer setting?
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
Mar 07, 2009 | Dewalt 18 Volt Compact Drill Kit
New cordless drill won't run with charged batteries
Does the drill do anything? Check in the cavity where the battery goes and make sure there is nothing there to prevent the battery contacts from connecting with switch. I take it the charger indicates the batterys are fully charged. If you cant see anything obvious I would take it back and get a replacement.
Dave
Dec 26, 2008 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Torque ring stuck in hammer on my dewalt dc935
remove the spindle housing ,turn the collar spindil, if i d'ont turn replace 629828-00 spindle & clutch assy.
if i turne check the transmission 613237-00
Nov 16, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
