Question about Craftsman Garden
Riding mower won't start, new starter, spark plugs an fuel filter. What should I check next?
Craftsman 19.5HP 42 with Brings & Stratton motor
    Top Expert:
  • Craftsman Master
  • 12,744 Answers
Check seat safety --brake /clutch safety
Posted on Apr 27, 2017
Testimonial: "Thank you"
  • 103 Answers
If it's carbureted, make sure the bowl float isn't stuck.
Another possible idea, and not saying that this is it, but many small engines have a small sensor that will hour allow an engine to run without having an adequate oil level.
My 21hp briggs engine won't start if I'm only 3oz low..
Testimonial: "Filled with oil before starting"
My riding mower won't start, new starter spark plug and fuel filter. Now what?
You did not post any information about the motor. There is a specific gap between the magneto and the flywheel and also the flywheel has a woodruff key to make sure the timing is correct. Check for spark, check gap on magneto and check magneto if you don't have spark.
Apr 27, 2017 | Garden
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
My craftsman riding lawnmower cranks over strong but will not start
Do you have spark? There are two things to look for when any engine won't start....fuel & spark, Take your plug out and lean it up against the metal of engine...turn it over and see if you see a good blueish spark.
No spark? Could be the plug, safety switch, coil
Next squirt a little gas into spark plug hole, replace the plug...will it fire up? If so...start working your way back down the fuel system....carburetor, fuel lines, fuel filter and gas (is gas old or new? is there any water in it?)
May 29, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
