Question about Garden
Riding mower won't start, new starter, spark plugs an fuel filter what can I do next?
  • 35 Answers
SOURCE: murray riding mower won't starter,
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Posted on Aug 25, 2011
  • 57 Answers
SOURCE: My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Posted on Apr 04, 2012
Testimonial: "I finally got it started after draining the gasoline out and replacing with new gas. It only runs with the choke engaged, but I'm going to seafoam the carburetor and add it to the gasoline."
  • 4 Answers
SOURCE: cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Posted on Aug 10, 2012
Testimonial: "I'll try this solution tomorrow. thank you for the help"
  • 16987 Answers
SOURCE: My riding mower won't start, new starter spark plug and fuel filter. Now what?
You did not post any information about the motor. There is a specific gap between the magneto and the flywheel and also the flywheel has a woodruff key to make sure the timing is correct. Check for spark, check gap on magneto and check magneto if you don't have spark.
Posted on Apr 27, 2017
  • 12774 Answers
SOURCE: Riding mower won't start, new starter, spark plugs an fuel filter. What should I check next?
check seat safety --brake /clutch safety
Testimonial: "Thank you"
Engine doesn't start and run...just turns over.
take the spark plug out and crank the engine over for 30 seconds to blow out any gas that may be in there. get another or a new spark plug and put it in and try to start it. maybe check compression to see if the valves are working properly. if you have spark and fuel and compression it should.
Sep 20, 2016 | John Deere Riding Lawn Mower. EZtrak Z225...
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Why do I have to use starter fluid to start?
Use high grade fuel with out the 10% elthal
Jul 24, 2014 | Craftsman Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
John deere lt 160 turns over but won't start
are you getting spark?is it getting fuel threw the carb
May 21, 2012 | Garden
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
Aug 25, 2011 | Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
