Question about GE Refrigerators
What is the coolant in model gfe29hsdss ge refridgerator
Where is the power button on ge arctica refridgerator model PSs26mgtb/ww
There isn't a power button that I know of on that model I know that it will stop running if the control board shorts out
GE Refrigerator Main Control Board WR55X10942
Aug 06, 2016 | GE Refrigerators
Why is my GE GFE29hsdss have temperature spikes. the tem in the fridge rises to 55 degrees and the unit does not turn on. this lasts for a few hours. i didconnect tne power to try to reset it. then ab
This seems like a compressor issue. You may need a new compressor or may be just a leaky gas (freon in the old days). Call a repairman.
Oct 12, 2014 | Refrigerators
Why is my Display not working?
I think that is a trouble code google applaince depot and call them and the can help u bettet
Jul 22, 2014 | GE GFE29HSDSS 28.6 Cu. Ft. French-Door Ice...
The house we moved into has a GE select side by side refridgerator with a water dispenser. I was wondering if it had a water filtration system and if not, is there a way to add one?
Most refridgerator filters on older machines are located externally. Without Model # it hard to say but I would look behind the machine for a cylinder about 10"-12" long and 3" in diameter. It would have a small either copper or plastic tube attached at both ends.
Jan 06, 2011 | GE Refrigerators
My GE model number GTS18DBMBRWW keeps clicking but
its your RTX overload contactor on the compressor body,getting weak and trying to hold contacts in to power the unit
Dec 16, 2009 | GE Refrigerators
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Fridge: PSS26SGPA SS Model
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
GE PFSS6PKWSS refridgerator side panel
not gonna find another manufactures product to match your dimensions, best bet is to find a local metal fabricator get a s/s panel cut to the dimension you need, silcone or a quaity double stick tape will secure it to where it needs to be
Mar 05, 2008 | GE PFSS6PKSS
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
