Question about Blenders
Attaching the motor of my ninja food processor to the blade
I am trying to make a smoothie. I am having trouble attaching the motor part of the ninja to the blade.
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
SOURCE: need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Posted on Sep 23, 2009
SOURCE: My Blade Base Won't Come Out
yup, same thing happen'd to me, turn the base in the oppisite direction...........
Posted on Mar 11, 2010
  • 41 Answers
SOURCE: ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Posted on Aug 18, 2012
odiebugs
  • 949 Answers
SOURCE: Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Posted on Mar 31, 2013
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
What is the best blender for making smoothies with frozen fruit?
There are many types of blender available on the market which perform a different operation. Some blender is famous for specific work. I would suggest you choose the blender which can perform all the blending operation perform in the kitchen. Ninja Professional Blender BL160, BL660, BL482, Cosori High-Speed Blender.
This all is the best budget blender for smoothies. You can get the comparison of all these blenders in one place, then you can choose the best one which is suitable for your kitchen.
k2-_dc60fae0-5edf-426c-815f-45fa26bb0c57.v1.jpg-a8dba74604930421996186d49210837d5e1c6aed-optim-450x450-1idkyi3fqqfoabkjwactfx1g-2-0.jpg
Jul 28, 2015 | Vitamix Blenders
Ninja blender 1100single server sticks after using hard to loosen
I experienced the blades freezing on a different blender after making smoothies and letting the unit sit for some time. The problem was sugar seeping into bearing interface and solidifying. I soaked the blade assembly in water and they freed up.
I now add water to blender container after each use and operate it until clear water seeps out the bottom of the bearing.
Oct 24, 2014 | NINJA Kitchen System 1100 - As Seen On...
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Mai
Jan 11, 2018 | Euro-Pro Ninja 1000 Watt Prof Blender 3...
My ninja base single serve button is always on, even with nothing attached and it can run with no attachment. I cannot use anything but the single serve.
read your owner manual section troubleshooting. However you must test the control board fro defective, but test the main switch for defective use the multimeter for continuity and replace it
God bless you
Nov 04, 2013 | Euro-Pro Ninja Kitchen System 1200...
Ninja blender blade wont turn with food in container.
Aug 18, 2012 | Blenders
Need to order parts for food processor for stainless steel blende
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Blenders Logo
119 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
