Question about Kenmore Refrigerators
How to remove the freezer air grill on kenmore model 59663222200 grill number67001079
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
Jul 17, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The freezer will not stop runnig
Refgriderators loose some of there cooling capacity if the condensor coils are not kept clean .To clean the coils pull out the fridge, remove the front and back bottom grill and vacoom or blow all the lint off the grills.If blowing out ,it can get messy.I usually put the vacuum in the back,cover the rest of the opening with a towel and use air to blow from the front.Hope this helps if so please give us a 4 thumbs up. THANKS
Mar 03, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
I have a Kenmore model#10648062890 bought in canada, frost is building up through out fridge and freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
Dec 11, 2009 | Grilling
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My Kenmore side by side Model #10654393300
repl thermostat and set freezer air control to the middle
Oct 24, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 74292
the water filter, according to the model number shown for which you listed this request, is located at the botton of your ref. Open the door and look in the grill area about the center, you will see a opening of a round whole. Twist the cap to the left 90 degrees and pull out. make sure when the filter goes back in that you dispense about a picture of water so that the air in the line is removed or you will have a run on of water untill all the air is out.
Sep 06, 2008 | Kenmore 74292 / 74294 / 74299 Top Freezer...
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Kenmore Trio 596.735073200 Frig & Freezer aren't working
Behind the removable toe plate at the bottom front there is a wire grill condenser. Using you vacuum cleaner and crevasse tool clean it out as best you can. Sometimes it helps to blow out this area with compressed air.
Next look for frost on the back wall of the freezer section. If there is frost you have a defrost system problem. Let me know what you find.
May 30, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore freezer
the condenser is usually located on the bottom removing a small panel on the behind or its a black grille behind the unit
May 02, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
