Question about Sony PlayStation Portable (PSP) Console
Psp dns error version 5.51
My dns dose not work it did but it stop.i do not no why.i did help!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 13 Answers
TRY FLASHING YOUR DS POP OUT THE BATTERY IN THE BACK LEAVE IT OVERNIGHT AND PUT BACK IN TA DA FLASHED AND DNS SHOULD WORK NOW
Posted on Jul 25, 2009
Pasquini Livia 90 Auto Dose Panel
First, I'm not a Pasquini tech, but I have worked on several similar brands.
* Most Semi-automatic machines will usually have the program button on the same as the stop button. Some will program all the groups at once or can be individually set up for different pours (shots)
* Holding down the program or stop button for 5-10 seconds will activate the program mode. Note that if you don't press any dosing buttons after 5-10 seconds the program mode will revert to normal mode. Some may cancel out the previous dose set up.
* Before starting, determine what you want a shot to look like. 1 oz, 1.5 oz, 2 oz., etc.
* Set up your portafilter with ground coffee. DONOT change the grind size once your satisfied with the QUALITY of pour (don't confuse this with the amount of the dose. This is handled with the programing of dose water.) Water is absorbed by the grounds depending on the grind size and some times the amount. Pods are different from loose ground coffee too.
* Load up portafilter and place measuring cup(s) under spout(s).
* Press program button and hold for 5-10 seconds. The button will light and stay on (some blink).
* Press the dose button for the appropriate portafilter you have mounted. The pasquini requires you to press the stop/program button once you have achived the desired dose. Other brands require the dose button to be press and held down until the amount of dose water is reached. Letting go button logs the amount in but only after pressing the stop button does it set.
* For other brands, you may need to set up all buttons prior to pressing the program/stop button to confirm dosing of all buttons.
* Remember to keep reloading fresh coffee grounds in the portafilter for each adjustment. Used (wet) coffee will throw out the water dose calibration.
Aloha, ukeboy57
PS; I found a good video from Whole Latte Love site:
https://www.youtube.com/watch?v=1NGN55nYBxQ
Mar 11, 2018 | Pasquini Coffee Makers & Espresso Machines
Semi automatic espresso machine shot won't stop pouring
Continuous water flow indicates a stuck valve. These suggestions may help depending on type of machine:
Full Automatic (Super Automatic); Valve needs back flushing, cleaning, or replacement. There is an off chance the dose needs re-programing.
Semi-Automatic; Valve needs back flushing, cleaning, or replacement. Check programing for dose.
Manual; Most manual espresso machines require operator to stop dose. (By releasing dose button or lever)
Arm style Manual "Jaw Breaker"; These are physically chambered dose which are unable to constant dose. Bad seals needs replacement (if you can still find them)
final comment to this 'open' question; All coffee machines needs periodic cleaning. Most espresso machines needs back flushing (not to be confused with de-scaling.) Usually a cleaning tablet or powder is poured into dose chamber (or back flush portafilter) and cleaning cycle or long dose is performed. This cleaner will loosen baked in coffee and push it out the pressure relief pipe. The machine will need to go into a normal dose cycle without coffee to flush the cleaner out of the valve and dosing system. Do this several times. Good daily cleaning habits will keep your machine in top condition.
Sep 30, 2017 | Coffee Makers & Espresso Machines
DNS connecting problem
Try restarting your DNS client setting
Instructions
    • 1Click the Windows "Start" button and select "Run." Enter "cmd" into the text box and press "Enter." This starts your Windows command prompt.
    • 2Type "net stop dnscache" to stop the service. It may take a few seconds for the service to stop.
    • 3Type "net start dnscache" into the command prompt and press "Enter." This restarts the DNS service on the machine. The DNS service restarts.
Or you Contact you Internet service provider they should provide you their DNS setting
Oct 31, 2012 | Advent Computers & Internet
Dns error
DNS stands for Domain Name Service, and it helps in accessing various websites on the Internet. An error regarding the DNS for any particular website usually implies the lack of an active Internet connection. The purpose of DNS is to simply translate the address that a user types on the web browser from the human language into the computer language.
DNS is used to resolve names to numerical IP addresses, which is needed to route traffic onto the Internet. Whenever a URL is entered into the browser, the beginning part is the website's domain name.
One Website Not Working: try contacting other sites on the Internet to see if the DNS error is particular to one website. If only one site is not working, the problem rests with the one website.
Computer Not Connected: another item to check when a DNS error shows up is to see if the computer is on the local network. Check to see if the home or office router can be reached from the computer. If not, the DNS error is from the computer not being able to connect to the local office or home network.
Internet Connection Down: if no websites are working, it might be because the Internet connection is down due to a faulty cable/DNS modem or the ISP is down. Power off and on the modem. If the DNS errors still persist, contact the ISP.
DNS Errors: in the vast majority of cases, DNS errors have nothing to do with DNS. DNS errors are usually one of the first symptoms of internet or wireless connectivity issues.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Sony Playstation 3 (PS3) Console
I need help getting online with my PS3. When I
Your DNS is generally your router or access point. That resolves DNS requests as either internal (on your network) or external. If external it forwards the request to the ISP's server. Check the gateway IP on your PC. If it doesn't work then try entering the DNS server for your ISP directly.
May 01, 2010 | Sony Playstation 3 (PS3) Console
My son has a DNS error on his PS3 and cant get onto the internet....can you help a technophobe
this has helped me in the past.. i hope it helps you out
Been troubled lately by that pesky DNS error? Notice that your PS3 can still browse the net, but not log in? Happen to be a Roadrunner customer? Happen to have any other ISP with a crummy DNS server? Well then read on...
The main issue turns out to be a Roadrunner (or any other ISP's) DNS problem. The fix is simple. When configuring your PS3 network (regardless of wired or wireless), use the manual option. If you use DHCP, leave address resolution at automatic BUT CHANGE THE DNS SERVER ENTRY TO MANUAL.
I replaced the Roadrunner (or any other ISP's) DNS entries with addresses from the Open DNS project which is a free, secure DNS server that anyone can use. It's safe, easy, and works.
The DNS addresses are:
208.67.222.222 or/and 208.67.220.220
Once replaced, you should have no problem logging in.
here is the url i got it from http://boardsus.playstation.com/t5/PlayStation-Network/Solution-for-your-DNS-error-80710102-problems-Works-for-all-ISP/m-p/42264211/message-uid/42264211
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
D:/windows/system32/shdoclc.dll/dnserror.htm
Hi hemgri,
the answer to this problem is unfortunately not that easy, because multiple reasons can cause this error.
It could be a simple DNS or DHCP service error, that can hopefully be fixed by restarting the services
  1. Go to Start>Run and type "services.msc" and click ok
  2. In the list look for "DHCP Client". Right-click and choose Stop
  3. Then right-click "DHCP Client" again and choose Start.
  4. Then look for "DNS Client". Right-click and choose Stop.
  5. Once again right click "DNS Client" and choose Start.
  6. Double-click your Internet Explorer button and all should be working now.
It is also possible that your DNS server is not working properly. What ISP do you have and what are your DNS servers? Try assigning a static DNS server.
  1. Go to Control Panel>Network Connections.
  2. Right-click on Local Area Connections and go to properties
  3. Double-click on Internet Protocol (TCP/IP)
  4. Chose "Use the Following DNS server"
  5. Type in 4.2.2.2 on the first line and 4.2.2.3 on the second line.(These are Verizon's DNS server.) Click OK.
We are just going to use theseDNS to see if there is something wrong with your ISP's DNS. Try browsing and see if it works. If it does, you can also use one of the open DNS servers instead of the one's from your ISP, i.e. OpenDNS's free DNS servers: 208.67.222.222 and 208.67.220.220.
If this still doesn't work, then there is a possibility that your computer is infected with a virus. To do something about that would be too much for this forum, because it involves posting of 'HijackThis" logs. Have a look here, someone had the same problem. Try to find help there - the guys are really good and know what they're doing.
Please leave a comment, so I (and maybe others) can learn more about this.
Jan 08, 2009 | Microsoft Windows XP Professional
DNS error
to fix to the "DNS error" in windows
XP. go to>Control Panel -> Admin Tools -> Services
Find DNS Client and Stop it, wait a few seconds. Then start DNS CLient
again. Can continue without rebooting or reconnecting.
.hope this helps pls appreciate by rating it
Oct 23, 2008 | Dell Dimension 2400 PC Desktop
HELP MEEEEEEEEEEEEEEEEE
192.168.0.1 or http://192.168.0.1/index.php
this is your modems default web page
default username is admin/Admin
default password is password/Password
this should work for all routers if this dose not work put your routers ip in the top bar no www. needed
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation Portable (PSP) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
