Question about Bosch Washing Machines
Bosch wfvc544auc/20 front load washing machine. door will not unlock code e13 is displaying. how do i get the contents within the machine out
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: door locked and won't open
Hello and welcome to fixya. The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely. You haven`t mentioned if you`ve checked the pump...just hoses as you did mention. Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly. Thank you for coming to "fixya" and good luck. macmarkus :)
Posted on Jul 10, 2010
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: THE bOSCH 300 SERIES WASHING
Hello, welcome to FixYa.
The E13 error code on most series Bosch including the "Nexxt" series washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to extremely sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Sep 01, 2011
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Jan 31, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch WFVC544AUC won't spin, can't get filter out
If the washer won't spin or agitate,
1. Check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
2. Or, the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Thanks!
Feb 11, 2014 | Bosch WFVC544AUC Vision 500 Series 27"...
Cannot remove filter for bosch wfvc544auc
the best way is to remove the pipe to the pump then slowly remove bits then the filter will come out
be gentle do not force it
I have a front loading Bosch washing machine and it was working fine on Friday. On Saturday morning I went to take a load of clothes out and the door won't open - I am getting an E13 signal. My...
Hi!
The door lock uses electrical power to keep the door closed. Unplug the machine from electrical power and the lock will be released in a couple of minutes. Please be sure not to flood the room if the water level inside is above the door level.
Regarding the E13 error itself, it means too long draining time, and it can be caused commonly by something stuck in the drain filter. To get to this filter and clean it, you have to look at the lower part of the machine and remove the circular panel, then insert a little screwdriver into the hole and twist , the acces pannel will get open. Now twist the handle of the filter and pull it out. Now it can be cleaned. CAUTION: opening the filter will cause all water inside the machine to get out, so have some towels handy to avoid water to spread all over the floor.
Hope it helped,
Bogdan
Aug 28, 2011 | Bosch Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Will not drain
Hello, Welcome to FixYa. You've stated that the drain hose has been checked, have you also inspected inside the drain pump ? Does the unit display any error code, i.e. E13 or E04 etc ? Also if you could varify the unit is indeed a WFMC6400 before going much further it will save on potential mis-information...its best to be clear from afar. I'll watch for your reply so we can move towards a solution for you. macmarkus :)
Jul 11, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
E13 error- can't unlock the door
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Apr 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
