Franke Little Butler Water coming out (hot side) has a lot of floating sediment? Just changed the filter, but didn't resolve the problem.
SOURCE: Franke Little Butler instant hot water dispenser
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Posted on Nov 22, 2008
SOURCE: White sediment in the hot water
replace heater-have u ever drained heater?turn off water supply-drain heater .try this a couple times.if u replace heater put water filter on incoming water.
Posted on Jan 08, 2009
SOURCE: Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Posted on Jan 11, 2010
  • 2006 Answers
SOURCE: Hello. I recently
If you can find a hose that will fit the water line you can flush it out. But the most likely problem is that the filter that you bought was defective and the white particles are coming for it. If you can test it without the filter, to see if the water is clear or not, will tell you whether you should take the filter back and complain.
Posted on Jun 08, 2011
  • 1833 Answers
SOURCE: Frank Little Butler hot water heater.Very hot
It sounds like you have a bad temp control board. You may need to replace it.
Also check for sure that the anode rod working properly.
Good Luck.
Posted on Aug 01, 2011
My little butler has started spitting hot water when in use.The filter is new and the temp setting has been turned down. Any ideas?
The seals have gone. This is typical of any hot water dispenser that directly heats the water while it is under pressure. The water expands and eventually ruptures the seals. Typical life time of this type of water heater is 2 years. Through it away only this time buy the non-pressurize type of instant water heater. Search the web and you will find a few brands.
Nov 04, 2014 | Franke The Little Butler LB1000 Instant...
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Franke instructions
sounds like the little butler is shorted.
Jul 03, 2014 | Franke LB1100 the Little Butler Series...
Franke water coming out of hot water handle after I changed the filter
It sounds like the cartridge is not properly seated against the O ring. I am not familiar with this exact model but remove the filter, check and be sure the o rings are ok and re install the filter.
Mar 04, 2014 | Franke LB2200 Instant Hot and Cold Water...
Replace Neopreme Hose on Franke FH160?
Take the whole valve and hose out and go to hardware store etc. That undersink unit is discontinued
Jul 09, 2013 | Franke LB1100 the Little Butler Series...
Hello. I recently changed my water filter (puresource2) on a side by side. The water coming out now is cloudy. It looks like little white particles floating in the glass. I didn't notice it that...
Jun 08, 2011 | Frigidaire FRS23KF7AB Side by Side...
I can't find the reset button on my franke garbage disposal
On most franke disposers, the reset button is located inside a small indention near the bottom on the side of the unit.
Feb 11, 2010 | Franke WD-3428 Little Butler Garbage...
Apr 13, 2008 | Franke WD751B GPS Receiver
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
