Question about Fisher and Paykel Refrigerators
I have a fisher and paykel upside down fridge freezer and the light at the back keeps flashing. I defrosted it yesterday.
hotuna
  • 288 Answers
SOURCE: very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Posted on Feb 16, 2008
22yooper
  • 828 Answers
SOURCE: my upside down fridge freezer
Beeping noise can be caused by door being ajar. Check product storage and make sure something is not preventing your door from fully closing.
Posted on Apr 29, 2008
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
woodchuck789
  • 4070 Answers
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
  • 5 Answers
SOURCE: How do I defrost the freezer of my Fisher Paykel
its easy, just open the freezer door
Posted on Feb 17, 2010
Fisher and paykel n405l fridge freezer .Freezer on top is working but fridge not working
There is a problem in the defrost system. Could be the defrost timer, defrost heater, or defrost safety thermostat.
Jul 14, 2014 | Fisher and Paykel Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
My fridge is not working
sounds like the ptc overload on the compressor has gone out,unplug it off the compressor and get an exact replacement ptc
May 01, 2012 | Fisher and Paykel Refrigerators
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Oct 04, 2009 | Fisher and Paykel Active Smart® E522BR...
In the fridge the setting panel green lights keep flashing fisher paykel
if you leave the door open too long it will flash a warning
close the door and make sure it is tight .
if this doesnt work , just unplug the fridge and plug back in aftera couple of seconds, this will reset the unit and should solve your flashing problem
Oct 03, 2009 | Fisher and Paykel E522BRXFD Stainless...
Frigde not cooling bottom freezer all frozen up on back plate
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2008 | Fisher and Paykel E522BLX Bottom Freezer...
Very hot compresser upside down fidge
Feb 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
