Question about Minka Dryers
I have a 96 Minka fan and tried to use it for the firs time since last fall, all it will do is move forward and back about a foot, it's less than a year old, can't find the reciept
  • 4 Answers
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Posted on Mar 31, 2008
SOURCE: F519-ORB stopped working
the first thing i would check is the wire connections under the cover at celing possible loose connection check wire nuts be carful turn power off befor serviceing ps dumb question is the switch on
Posted on Apr 14, 2010
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Posted on Apr 23, 2010
  • 1116 Answers
SOURCE: cloth will not move forward
Cogs are feed dogs.
Check your manual to see if there is a pressure adjustment for the presser foot.
This may be a nob on top of the machine directly over the presser foot.
Turning the adjustment left/less or right/more pressure.
Also, refer to the manual for cleaning the bobbin and feed dog area as lint may be causing a bit of the problem.
Posted on May 01, 2010
Testimonial: "Thanks.got it moving! Sorry forgot to tell u before"
I can not remove the glass dome to change to bulb on my Minka Aire 3 blade ceiling fan. I believe the model number is UC7084T
Push up on the glass all around to loosen it (be careful not to break). You could also spray a little WD-40 around the top of the glass. If these don't work, you might have to break the glass. Call Minka Aire @ 1-800-307-3267 and let them know the problem and they might send a replacement at no-cost.
Jan 03, 2016 | Minka Aire Ceiling Fan
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is. fanman9952@aol.com
Feb 28, 2014 | Minka Dryers
Minka Aire Ceiling fan turns on by its self
Try changing the frequency in the receiver & transmitter.
Mar 19, 2013 | Minka Aire Ceiling Fan
Cloth will not move forward
Cogs are feed dogs.
May 01, 2010 | Elna 2005 Mechanical Sewing Machine
Dec 27, 2009 | Minka Aire Ceiling Fan
Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Sep 08, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Dryers Logo
23 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
