Hi i need help with mp3 player
My mp3 player wont turn on. it charges. i try to turn it on while charging and it acts like it will turn on but stops. i have had it for 8 years or so. i need help?
SOURCE: my mp3 player wont turn on.
hiya I have a sony bean too and it does exactly the same thing as yours, if you havent sorted it out yet all you have to do is look under the usb flap and you will see a reset button, push it gentally with a pin, it will work agauin and you wont loose all your music, hope this helps
Posted on Feb 03, 2007
  • 5 Answers
SOURCE: Wont work
Hold the Power switch to the off position for 13 seconds it will reset the system (it wont delete memory)
Posted on Feb 19, 2009
SOURCE: redgroove mp3 player wont turn on
You have got to reset the MP3 player. To do this you have to use a paperclip (or something similar) to press the button next the hold toggle it should have the word RST.
Posted on Feb 25, 2009
  • 1031 Answers
SOURCE: My Element mp3 player wont turn on
When your player freezes, it will only start up and not play the songs or even the buttons won't respond to your pressing them, it is more like your computer hanging and never coming back to working fine unless you restart it. The first thing you should try to do is read the instruction manual and check where the reset button in your MP3 player is. Take a small pin and push the reset button. This will make you player go off for and then you can put it on again and it will work fine. However, there is a possibility of data loss when you reset. Most of your stored stuff will be gone after reset. Another thing that you can do to retrieve your player is doing a firmware update. Do a refresh of your firmware and see if it works, in most cases, it does. Other options are the same that you and everyone else will try as soon as you MP3 player freeze. That is opening the MO3 player and taking out the battery. Set the battery back and push the power button again. It is always a good idea to do a firmware upgrade right after .you can also open it up and blow on it.
Posted on Sep 30, 2009
  • 1456 Answers
SOURCE: i plug my mp3 player into the usb port on my
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Posted on Apr 30, 2011
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
My RCA Opal MP3 wont show up on my computer and it wont charge
This is battery problem, since it work with your computer directly, you no the computer power supply charge it directly so all you need do now is to get another battery and make sure you charge the new battery for some time before you power on.
Compliments and best of luck
Dec 25, 2009 | RCA OPAL M4001 MP3 Player
Sony mp3 wont turn on or charge
Hi ramoncuaya,
There seems to be something wrong with the device itself, two weeks is too little of a time for it to malfunction. If it is still covered by the warranty, take it to a service center. But it is also not advisable to leave it lying around non-operational for over a month.
Nov 30, 2009 | Sony Audio Players & Recorders
Mp3 wont turn on...
Press the Reset button then try charging it and if it doesn't begin to charge then take it to Radio shack.
Jul 28, 2009 | SanDisk Sansa m250 MP3 Player
My mp3 wont stop charging which keeps me from
The fact that the unit is charging has nothing to do with the problem you're experiencing. Most mp3 players, including iPods, charge the entire time they're connected to a computer. If you're unable to transfer your music files to the player, something else is going on. Can you tell me exactly what happens when you try to add a song to the player?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Jul 22, 2009 | SanDisk Sansa m240 MP3 Player
My mp3 player
The user guide (p 7) mentions pressing the Power On/Off/Stop button (presumably only once, but see below) to charge the battery if the charging does not start automatically when the uncharged player is connected via USB.
The following is from Memorex online FAQs. Hope it might be helpful:
Connect the player with the supplied USB cable. After the cable is connected, press the power button twice. The battery icon in the upper right corner will start filling with bars as it charges.
Jul 29, 2008 | Memorex MMP8565 MP3 Player
Help me with my mp3 player!
hay take it back to shop aned get a new one
Jun 03, 2008 | Samsung YP-K3 MP3 Player
Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
Mar 12, 2008 | Coby MP-C7085 MP3 Player
Wont charge and memory corrupt even after i reset tons of times
Plug your MP3 Player into your Pc and Format The removable Drive Then Re-load your music onto it if that doesn't work it'll have to be a hardware problem my only other suggestion is get out your Guarantee and send it in
Jan 15, 2008 | Philips SA5125/37 MP3 Player
21 people viewed this question
