Just bought a second hand Sony dav-s400 system and I want to find av leads to connect the system to a TV with a scart connection. Can you tell me where I can find one please ? Many thanks. Gary H.
Just make sure that you are using cables that are configured correctly physically and check to make sure that you are using the correct analog or digital signal necessary. Your audio settings need to be checked out and set accordingly. Check directions carefully.
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
not unless there is a vga connection or a s video connection on the unit. if so s video cable male to male should work then you have to go into the video card settings on the laptop by right clicking the desktop and selecting porpeties. then adjust settings to transfer image from laptop to tv
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one. Go to menu of home theater system and enable surround. Need further help, let me know please...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
