Question about Toys
How to figure out how many pounds is 109.884kg
  • Toys Master
  • 3,977 Answers
2.2046226218 pounds to 1 kilogram
109.884 x 2.2046
or use an online converter
http://www.rapidtables.com/convert/weight/kg-to-pound.htm
242.25275218 pounds
Posted on Apr 27, 2017
How many cups in 1.75kg
Let's figure it out.
1 pint is about 1 pound.
1 kilogram is 2.2 pounds
so, 1.75 kilos is about 2 pints, or 4 cups.
Jun 09, 2015 | Pool & Spa
Pogo moon stick doesnt bounce. How do u get it to bounce
I bought it too it didn't work either but I'm only fifty pounds so, my grandma tried and she is 135 pounds and it worked so, GAIN MORE WEIGHT!
Jun 17, 2012 | Pogo Moon Stick
Hi, I need to know what size loaf of bread my bread maker makes so I can figure out the recipes it will make. It doesn't say anywhere on it what size loaf pan it has. The model # is: WS0598 Thanks!
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Apr 13, 2011 | Williams-Sonoma Kitchen Appliances -...
Weight of 8 litres in pounds
You can't convert litres to pounds, at least not directly. The litre is a volume measurement, not one of weight (mass, actually). A litre of one material may not have the same mass as a litre of a different material, so a simple conversion factor doesn't exist.
If you know the specific gravity of the material you want to measure, you can convert the volume to a weight. Water is defined to have a specific gravity of 1.0, and 1L of water = 1 kg. One kilogram is approximately 2.2 pounds (you can look up the conversion factor if you need more accuracy). So if you are dealing with water, 8 L is around 17.6 pounds.
If you aren't measuring water, find the specific gravity of your material, and multiply by that value. A liquid with a specific gravity of 0.75, for example, would have mass of 0.75 kg per litre, so 8 L of that material would weight 0.75 times (or 75%) of 17.6 pounds. But without that specific gravity figure, you can't convert litres to pounds.
Feb 09, 2011 | Office Equipment & Supplies
1.0 dozen oranges has a mass of 9.0 pounds. if the volume occupied by 6.0 oranges is 2.0 quarts, find the volume of 25 pounds of oranges?
9lb/12 oranges= .75 lb/orange
2qt/6 oranges=.33 qt/orange
25lb oranges/.75 = 33.33 oranges
33.33 oranges x .33qt/orange = 11 quarts
Feb 26, 2010 | Educational Insights Hows and Whys Of...
Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
May 12, 2009 | Ford Escort Cars & Trucks
Pound Key
Open a notepad and then press all the key on keypad and check which one is giving a pound key. This is required because if the key cover is changed in that case the pound will work when pressed a different key.
Also clean the keypad or else get a new one.
Thanks
Oct 31, 2008 | Toshiba EKT6520SD Phone
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
