Question about The Kitchen Appliances - Others
I have a FrigoGranita slush puppie machine by Ugulini. The left side is freezing and turning properly but the right side is only freezing and the outer spiral is not turning. Can you help me?Heather
5 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: i have a dual machine. the left side freezes
Check the temp sensor on the machine(each side has its own sensor).
Posted on Jan 26, 2010
projdoc
  • 2236 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
  • 823 Answers
SOURCE: FrigoGranita MT2ULBL will not make slush.
The unit comes with the frost set at a default. You need to adjust the frost to fit the mixture and consistency that you are making in your machine. To change the frost and lower the temperature so that the compressor will continue to run once the the product is added you will need a screw driver.
The instructions on how to change the frost level and temperature on your machine are on page number five of your instructions manual. Just in case you dont have a copy of it, here is a link to download a free copy:
http://www.webstaurantstore.com/PDF/385MT1PUL.pdf
I believe its counterclock wise to lower the temperature? I would refer to page five for exact instructions.
Posted on Jun 19, 2011
projdoc
  • 2236 Answers
SOURCE: Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Posted on Jun 13, 2015
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
Hi my double barrel slush puppie machine keeps freezing up and stops it from turning and mixing suction . Have trted all the temp setting . Thd solution is mixed right
the machine freezes and stops based on the thickness of the slush. if it's mixed right, the problem is the torque switch next to the motor (if it's a cab or a ugo machine) or the torque sensor (for torque sensor models)
Oct 21, 2014 | Kitchen Appliances - Others
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
Ugolini slush machines
check the left side condenser coils, make sure they're clean. there might be low air flow, and that'll cause the compressor to overheat and shut off. leave at least 6 inches of space on both sides of the machine for it to breathe. also if the ambient temp is too hot, same thing.
Jun 26, 2014 | Kitchen Appliances - Others
Where is the reset switch on a slush puppy machine
cab faby? on the right front panel towards the bottom and behind the sticker there is a hole. inside the hole is the reset button.
May 30, 2014 | Kitchen Appliances - Others
Why is slush machine only freezing on one side
if it's a cab faby and it's the right side not freezing but getting cold, you have low refrigerant. if it's warm, you have a stuck solenoid, blocked capillary tube, or a bad torque micro switch. if it's a bunn ultra 2, you have a bad solenoid or the freezing button is not on freeze.
May 16, 2014 | Kitchen Appliances - Others
The left side of the machine is freezing, but it's pushing all of the frozen product to the top of the lid and overflowing
each side should only have 2 to 2 1/2 gallons of mix. there is a line on the bowl that is the max fill line. as it starts to freeze, the auger pushes the product to the front and up. if it's too full, it'll over flow. just empty some out.
Nov 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Kitchen Appliances - Others Logo
37 people viewed this question
Top Kitchen Appliances - Others Experts
Brenda Landram-Pope
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
